Axel seals
Old Aug 25, 2006 | 01:45 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Axel seals
We just took our 2004 F150 4wd into the dealer to have it checked out since the warranty runs out at 36000 and we have 34000 on ours. They found a bad axel seal and replaced it. Has any one else had problems with axel seals?
Old Aug 25, 2006 | 02:19 PM
ford9c's Avatar
ford9c
Ive seen that posted a few times. Good you got it fixed under warranty.
Old Aug 25, 2006 | 05:14 PM
Buck230's Avatar
Buck230
Yep, they just fixed mine this week. under warranty of course
Old Aug 26, 2006 | 09:15 AM
grey77's Avatar
grey77
Was there any evidence that the axle seals were leaking or bad? Can you provide additional information - wondering what to keep an eye out for on my truck.
Old Aug 26, 2006 | 12:11 PM
fordman19762003's Avatar
fordman19762003
if the axle seal goes bad there will be a wet spot around the hub where the rear wheel bolts on. With drum brakes it will be easily noticed because the lube runs down the back of the drum, but without drum brakes you might have to look a little closer around the inside of the wheel to see it. I haven't had any problems with my '05 yet, but I had both axle seals go out on my '97 at 34,000 miles.
Old Aug 26, 2006 | 03:51 PM
Ford150/428/dud
Yes i was told that there was a little fluid leaking from the seal, when they serviced the brakes. Sounds like this has been a frequent problem.
