Modular V10 (6.8l)
Another code ?
Old Aug 25, 2006 | 06:40 AM
MXZX1100cc's Avatar
MXZX1100cc
Another code ?
My service engine soon light came on the other day, so I got the superchips micro tuner out and did a test. It said PO401 and that is exhaust gas recirculation flow insuff detected. My ? is what the heck does that mean? Thanks
Old Aug 25, 2006 | 09:09 AM
rlh68050's Avatar
rlh68050
What year V10 do you have?.
Old Aug 25, 2006 | 10:31 AM
FortyFords's Avatar
FortyFords
Its usually the dpfe sensor ,either the vacum tubes are clogged or broken /leaking vacum.or the sensor is bad or no voltage for the circuit.
The egr could also be bad ,but highly unlikely.
Can be tested with a handheld vac pump.
p0401 is insuffiecnt egr flow ,that is measure by the dpfe sensor signal
Rich
Old Aug 25, 2006 | 12:30 PM
rlh68050's Avatar
rlh68050
Rich
Exactly what I was thinking. Although my 2001, does not have EGR.
Old Aug 25, 2006 | 01:03 PM
FortyFords's Avatar
FortyFords
his is a 99 ,by his sig
Rich
Old Sep 20, 2006 | 07:54 PM
cpufed's Avatar
cpufed
I'm having this same exact problem, same truck. A day before the check engine light came on the truck ran real rough and almost died when idling. Now it runs fine but the light is still on. If it is the dpfe sensor where is it located on a 99 Super Duty V10?
