Lastest Ford TSB On Transmission Fluid
Mercon V Use in Mercon Transmissions:
Effective 6-29-4, Ford is discontinuing Mercon ATF licensing and manufacturing. Mercon V is now approved for use in all transmissions specifying Mercon. This includes both the E4OD and 4R100 automatics (but not the 5R110 TorqShift), and the ZF six-speed manual, as well as the transfer cases. Once exsisting stocks of Mercon is depleted it will no longer be available. Transmissions that specify Mercon V should still use only that fluid. The ZF five-speed will still use synthetic Mercon, and the TorqShift still uses Mercon SP. TSB 06-14-4
