Hurkin' big driveshaft
Old Aug 24, 2006 | 03:02 PM
eigenvector's Avatar
eigenvector
Why is the driveshaft on my 2000 Ranger so huge? It's a massive piece of obviously welded aluminum.
I vaguely remember hearing something about this in the forum a long while back but this is a new truck - welding on metal hardly seems like a solution you'd find on a production line truck.
Old Aug 24, 2006 | 06:41 PM
RangerPilot's Avatar
RangerPilot
Did you buy it used? I'm pretty sure it'd be aluminum, but welded "obviously" is odd... Any pictures?
Old Aug 24, 2006 | 07:48 PM
eigenvector
No I got it brand spanking new, but I can snap a few shots. Maybe I'm mistaken about the welds, hard to tell sometimes lying on your back in the shadows looking at a greasy hunk of metal.
Old Aug 24, 2006 | 08:07 PM
Cheggie's Avatar
Cheggie
Umm, the entire body is welded together from stamped panels of steel, the frame is welded together, and yes, the driveshaft tube has to be welded to the yokes at each end.
Hee Hee! - all kidding aside, you might be looking at the weights that were welded on to balance the driveshaft. They would look like a curved washer with a blob of weld on each end.
RangerPilot
Greasy? Got some oil or tranny fluid blowing back there on it? Pics would be cool. No obvious welds on mine...
Old Aug 24, 2006 | 08:41 PM
eigenvector
Well okay so it ain't greasy, in fact it's as clean as a whistle
But if that ain't a weld I'm blind or something. It is aluminum, it even says Alcoa on the side.
Old Aug 24, 2006 | 08:42 PM
eigenvector
But back to my question, why is it so frickin' huge?
Old Aug 24, 2006 | 08:46 PM
jjanssen's Avatar
jjanssen
From what I've been told, the torque is spread out better over a larger diameter shaft. That way they can use alum. which is lighter. If they made a smaller shaft out of alum, it would twist and then snap.
Old Aug 24, 2006 | 09:22 PM
RangerPilot
Right. Since it's aluminum it doesn't have the torsional stress of other materials (cast iron), and thus it would tend to wrap under heavy torque. Those welds are normal factory welds, I was thinking you meant like in the middle of the shaft or something.
Old Aug 24, 2006 | 09:23 PM
eigenvector
You know I didn't actually think that was the driveshaft. Looking at it I thought it was some sort of shroud or covering for the real one.
That doesn't explain the horrible weld job they did on the yolk side, but it makes sense to me what I'm seeing now.
Old Aug 25, 2006 | 08:39 AM
Alan D.'s Avatar
Alan D.
Cool, my new job, i am a roll technitian. I Work on the rolls that Alcoa uses to press its metals. funny how small the world is.
Old Aug 25, 2006 | 11:40 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Eigen, since we're both Engineers go have a lookie in your mechanics of materials book for the subject of torsional stress (f = Tc/J) and deflection. Think about torsional buckling too; it's for real and it has been addressed. As to why it's welded, can you imagine what that driveshaft would cost if it were somehow a one piece swaged or forged then machined part? Ouch!
*That weld you are looking at was not done by hand, it was done on a jig that rotates the driveshaft at a controlled rate of speed while the weld bead is being layed. BTW, I don't see anything *horrible* on the weld in your pic.
Old Aug 25, 2006 | 01:35 PM
Joelski's Avatar
Joelski
You must grind and polish those welds immediately. Otherwise, all those people under your truck will think less of you.
Old Aug 25, 2006 | 02:07 PM
eigenvector
Well I won't grind and polish the welds, which to me do look sloppy, but I guess the transmission don't care. I am getting a hankering for polishing those terribly rusted driveshafts and u-joints it's mated to. My god those things are rusty.
Old Aug 25, 2006 | 04:40 PM
RangerPilot
It is balanaced, so grinding the welds could create a problem; glad you're not going to.
