Sponsored by: Real Truck
Need some opionions ??
Old Aug 24, 2006 | 02:10 PM
Smokiesman's Avatar
Smokiesman
Friend of mine has a 2000 Dodge Cummins Dually that he uses to pull a 2 car wedge hauler in a 5th wheel hitch. He also has a 2000 Ford Lariet 150 crew cab. He would like to sell both trucks and get a F350 CC SRW to pull the hauler and use as a personal driver! The hauler and 2 cars are about 18 to 19 k ! What we would like to know is will the F350 SRW be stable enough to handle that kind of load? We have a lot of twisty rds up here in the Smokie Mtns!!The height of the highest car on the hauler would be upfront and I believe no higher most likely lower than some of those monster 5th wheel TT that you see goin down the road! I know there has to someone out there that would like to chime in on this! Thanks Guys
Smokie
Old Aug 24, 2006 | 03:15 PM
JRM6868's Avatar
JRM6868
If you are saying the wedge hauler and the two cars are 18-19 thousand pounds my diesel manual says a cc f350 w 3.73 rr has a max GCWR of 23000 lbs. That's not enough if I'm reading everything correctly.
Old Aug 24, 2006 | 03:23 PM
bobbo7915's Avatar
bobbo7915
yeah if your pulling 19k with a 7-8k truck that puts you way over
mizzitch's Avatar
mizzitch
If you were to do this I would advise good trailer brakes (the 05 and newer SD's have very respectable factory brakes), maybe a regearing to 4.10, and rickson 19.5" wheels and tires. Those three things could make the F350 more capable than the dodge.
Old Aug 24, 2006 | 09:23 PM
Smokiesman's Avatar
Smokiesman
The Dodge quad cab Dually is what we are using right now ! And yes the car trailer does have brakes! I don't dought the Ford will haul the freight ! Stablity in the curves is what we would like to know! Is SWR enough??
Smokie
pic of the trailer!
Old Aug 24, 2006 | 09:26 PM
Kep4's Avatar
Kep4
Jäger
I believe you would need a dualie for that load, especially with a gooseneck trailer. It would be far more stable.
Old Aug 24, 2006 | 09:36 PM
Smokiesman's Avatar
Smokiesman
Don't have the Gooseneck ! Use the same setup as 5th wheel!
Smokie
Old Aug 24, 2006 | 10:12 PM
JR55's Avatar
JR55
Smokie, we have a trailer identical to the one you pictured to haul cars to and from auctions, We`ve only towed it once with a srw truck and many times with the dually, BIG DIFFERENCE!! Dually is the way to go, it handles the roads here in West Virginia with no problem. We use a 04 F-350 4x4 6.0 DRW and it handles smoothly and plenty of power with 2 cars on it.
Old Aug 24, 2006 | 10:26 PM
Smokiesman's Avatar
Smokiesman
JR! That is what we use it for to! I am sure that the Dually would be more stable ! But we are trying to get away from driving a dually around small town doing errands ! SWR handles the everyday drivin and parkin a little eaiser!! I guess the down and dirty of it "can the F350 SWR handle this trailer! And thank you all for your comments! Keepem comin!!
Smokie
Old Aug 24, 2006 | 10:46 PM
biz4two's Avatar
biz4two
Arrow
After reading the posts...it is pretty obvious what the folks are saying, NO...the F350 SRW is not the truck you need. Should be a DRW truck only...
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Aug 24, 2006 | 11:09 PM
Dustin1690's Avatar
Dustin1690
Yeah pretty much the DRW would be the safest and stabilest to haul something like that even though they maybe a pain to park and drive
Old Aug 25, 2006 | 08:55 AM
mizzitch's Avatar
mizzitch
The 19.5" wheels and tires make a big difference from the factory 18's. Look at
http://www.ricksontruck.com
225/70R19.5 are the same as on a F-450. If you want stabilty from a SRW use those tires,the factory rear sway bar for the slide in camper package, and possibly the dually rear leaf pack. Other options - add a second leaf to the upper overload leaf or add air ride helper bags.
Old Aug 25, 2006 | 10:19 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
IMO I think driving a crew cab long box would be more of a beotch then driving a club cab duelly around town.
