i would have never guessed that IFS would be heavier than an SFA setup. I think most of it is the bulkhead around the front of the motor that ford calls "safety" that weighs a ton and makes ford trucks/suvs hard to work on.
Yes, it's all just extra weight until you have an accident and survive it.
i have never been in an accident (as far as in a vehicle) (knocks on wood). extra weight also don't always mean safer. IF that was indeed the case, NASCAR and IRL would be driving Mack Trucks.
I may be wrong on this, but I think that would slow them down considerably. I know if a honda and a Mack were to have a collision, I would prefer to be driving the Mack.
One thing I like about Ford superduties is I can change my oil without lifting the truck at all. On a Chevy its very difficult at ground level. I am firm believer in a SFA on HD truck. When your pulling a heavy load you wont have near as much sway from front to back as you do with a IFS system.
i agree with moldman7n, but in the same token, take both objects and roll them over, and the honda will probably fair better than the Mack.
BTW 150ford. I like the idea of not having to lift the truck to change the oil. But I have never had a problem with sway front to back.....or left and right for that matter with our 30' 5er.
yeah thats true on my 98 F-150 XL 2WD I dont need anything a wrench and a oil bucket plenty of room very easy change oh yee my trucks got 200,700kms and it runs like new gotta love the 4.2 1200 pounds of scrap metel doesint matter either cause fords just keep haulin
One thing I like about Ford superduties is I can change my oil without lifting the truck at all. On a Chevy its very difficult at ground level.....................I am firm believer in a SFA on HD truck.
Ha! It's funny you mention that. I change the oil in my truck here at work and when the guys see me slide a 5 gallon bucket under the running boards with 1/4" to spare, they all stare in disbelief. Ain't gonna be doin' that with a GM truck running boards or no.
I too am a firm believer in solid front axles. However, since I don't have the desire to lift another truck that I'm still making payments on (i.e. the monster truck), then IFS is beginning to look ok.
There is ONE major problem I have with these GM trucks. It's the steering. With my Ford, I can swat flies, sneeze, drink a big gulp and spill it all over the place and never loose my position in my lane. However, with the Chevy, one small twitch from a "mini-shiver" and you're swappin' paint with the guy next to you. The steering is far too sensitive.
Amazing- if Fords had placed in the truck pull this thread would be all about how great they pull and how the competition results prove it.
Oil change: my DMax doesn't require the 5 gallon bucket like my Powerstroke because the DMax only needs 11 qts, not 16.
For me, it is the exact opposite. If I drive a ford or dodge, it is like I have to actually watch what I am doing. I have to actually drive the truck. With a GM, I can put my hand on the wheel, and barely ever have to move it to get the truck to react. With a ford or dodge, I start moving the wheel, and I keep wondering to myself, when am I going to end up in the other lane, because it takes forever. The I normally end up having to correct myself if I am in a dodge or ford, because I always end up going too far.
Just the difference in trucks, but personally, I love the tight sensative steer a lot over the ford and esp the dodge. I have tractors that drive down the road better than some dodge trucks I have driven.
