Dome light wiring
Dome light wiring
I spent Easter weekend installing an alarm in my truck since some punk decided to rip my radio out of the dash a few months ago. During the process, I installed door jamb switches and wired up the dome light. For those interested in adding this feature, I will be adding the install instructions as well as photos to my homepage very soon. I realize it is just a simple set-up but just tickles me to open the door after work every evening and SEE the inside of my truck now!
Dome light wiring
K, that is one of the things that I want to do to my truck as well as adding a stop and cargo light to the back of the cab. I had thought about adding them to both sides over the doors. Haven't done much more than drive the truck, lately.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
John
jowilker email me
Dome light wiring
I also have thought about the door activated dome light, it would be nice! My truck still has the black rubber plugs in the lower door area. I am not sure if a door plunger was available on the 61-66, but after looking at some spare '72 buttons I have, I just might do it using them. Too bad I didn't save the wire harness from the '72 so I could adapt the Ford Wires!
Dome light wiring
I used grounding type switches found in GM vehicles so I lost the headlight switch feature and have to open a door to turn on the light. If you use early Ford switches, they cut out the positive side of the circuit and you can keep the headlight switch feature.
I mounted the jamb switches up near the upper door hinge between the bolt access and the lip that almost meets the door. This gave me the clearance I needed to not bend the switch.
Dome light wiring
John,
I had an idea the other day to use a third brake light/cargo light combo from a newer model Ford Ext cab. That could just possibly work, since both cabs are rounded right at the top above the rear window.
I could do some more looking into that if anyone's interested?
Oh by the way, I'm back! Now that I have some time off from work, thankfully. After Sept 2001, they were working us to death, 3 people covering 5 shifts. I had no time off. At one point I had worked 58 out of 64 days straight, and last month we figured the time up. I worked a grand total of 1800 hours from August until March.
Now it's time to play with the truck!
Dome light wiring
Kyle, my thoughts exactly.
John
jowilker email me
John
jowilker email me
Hell_Fish
Jul 7, 2014 10:46 AM
