D50?
Old Aug 23, 2006 | 09:05 PM
BigBody's Avatar
BigBody
D50?
Ok, I have a 84 F-150. The front end is out and have been looking for a replacement. I had planned on doing a SAS but currently just need a quick cheap swap. I came across a 1980 F-350 D50. Are they direct bolt ins? If not, what needs done to get it under the truck?
Thanks,
Kyle
Old Aug 23, 2006 | 10:18 PM
BigBody's Avatar
BigBody
Also, just now realized the axle would be 8 lug. If its a bolt in, how hard is it to make it a 5 lug d50?
Thanks,
Kyle
Old Aug 23, 2006 | 11:57 PM
big hoss 29's Avatar
big hoss 29
A Dana 50 isn't all that much beefier than a Dana 44. Besides, a Dana 50 is leaf sprung while your truck is coil sprung. Save yourself a headache and find a Dana 44 TTB if you need a quick easy swap, less fab work involved that way.
Old Aug 24, 2006 | 05:16 AM
Sycostang67's Avatar
Sycostang67
A D50 is pretty much a D44 center section with D60 outer ends. If you were to convert it to 5 lug you would just be making another D44, but with a lot of extra fab work to change it from leaf to coil sprung. It's not worth it.
