Sponsored by: Real Truck
Speed Control
Old Aug 22, 2006 | 11:54 PM
Marti501's Avatar
Marti501
Speed Control
Hi I'm new here.
Can anyone tell me how to change the Speed control switch on the shift lever? (automatic Trans)
Thanks in advance,
Marti
Old Aug 23, 2006 | 04:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 24, 2006 | 02:11 AM
Munkey's Avatar
Munkey
Speed Control = Cruise Control
What switch are you referring to, the 'Overdrive On/Off' switch at the end of the shifter stalk? Or are you referring to a control component inside the steering column?
From looking at the factory manual, I can't find any switches, other than the ones on the steering wheel, that relate to the cruise control anywhere near the shift stalk...
Old Aug 24, 2006 | 08:50 AM
Marti501's Avatar
Marti501
Thanks for responding. I am referring to the button on the end of the shift lever for the overdrive. Sorry about that, it's the overdrive button I need help with.
Any advice is certainly appreciated.
Marti
Old Aug 24, 2006 | 01:00 PM
Munkey's Avatar
Munkey
Ah! Easy as pie!
Gently work a thin screwdriver, or even the tip of a knife between the end cap and the shift stalk. The cap goes on kinda like a bottle cap, it just pops on and off. The O/D switch just slides right out after that cap is off.
Hope this helps!
Old Aug 24, 2006 | 02:35 PM
Marti501's Avatar
Marti501
Thank you I really appreciate the help!
Marti
