Body swap
Old Aug 21, 2006 | 08:37 PM
pockets's Avatar
pockets
Body swap
Sorry guys, been a little while since I have had time to flip around the site. I am considering putting the body of my 65 f-100 onto a Ford 65 4x4 frame that I have in the shop.
I realize that the front fenders are shaped differently to allow for clearances, and that the wheel base is also different.Since this will not be used to go up mountains is there going to be a clearance problem? Also can I slide my rear end back to allow for the box to line up with the wheel well?
What is your opinion? I always liked the 4x4.
Frank
Old Aug 22, 2006 | 05:59 AM
jowilker's Avatar
jowilker
Frank, Anything can be done with enough time and money thrown at it. Sorry to advise that your 4X4 is based on the 61-64 chassis and things will not bolt up.
If your sheet metal is really good, you might want to look at spending that effort on a much newer 4X4 chassis. just a thought
John
Old Aug 22, 2006 | 08:18 PM
pockets's Avatar
pockets
thats too bad. The body is in great shape, could you recommend a newer frame that would work for an easy swap?
Thanks Frank
I will take a look through the old search button
Old Aug 22, 2006 | 08:26 PM
doc_f250's Avatar
doc_f250
73-79 F-100 thru F-350 are real close to perfect......
Old Aug 23, 2006 | 06:19 AM
jowilker's Avatar
jowilker
Doc, Are you sure on that??
John
Old Aug 23, 2006 | 08:52 AM
doc_f250's Avatar
doc_f250
I'm not even sure if I'm here.......
Just trying to help out w/ info learned & projects tried in the past.....
D
Old Aug 23, 2006 | 09:21 AM
jowilker's Avatar
jowilker
Doc, I believe the 65 4X4 frame from what others have posted is built on the 61-64 style and is different from the 67-79 series as you suggest.
If I am wrong I apologise, and hope someone can set it straight.
John
Old Aug 23, 2006 | 10:24 AM
doc_f250's Avatar
doc_f250
Thanks Frank
Looking for a newer frame for a great body......sounds like he's got a '65 2wd F-100.....most of the '73-79 F-series had disc brakes, etc.......
You tell me.
Doc
Old Aug 23, 2006 | 08:25 PM
pockets's Avatar
pockets
john is right about the 65 4x4 frame, they used the older style boxes. If I am going to upgrade my ride I may as well go with Doc and buy a donor truck 73 -79.
Thanks, Frank
Old Aug 24, 2006 | 05:11 AM
jowilker's Avatar
jowilker
Doc is a good man to go with Frank.
John
Old Aug 24, 2006 | 07:49 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
hey frank, where about you located?
i live very close to doc, need to go meet him one day..
Old Aug 24, 2006 | 09:10 PM
pockets's Avatar
pockets
Hey there Rick, I live in British Columbia Canada. It's a little out of my way but if you want to split the gas, give me a call.
Frank
Old Aug 25, 2006 | 12:25 PM
doc_f250's Avatar
doc_f250
We need to get up soon & talk trucks!! LOL
Doc
