View Poll Results: where should the antenna be mounted
passenger side tool box
21.43%
driver side tool box
14.29%
center of tool box front of box
35.71%
center of tool box rear of box
28.57%
Voters: 14. You may not vote on this poll
CB antenna
Old Aug 22, 2006 | 09:43 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB
Originally Posted by kjg26
i have about 5 extra feet just piled up under the seat. could this be my problem?
that actually could be contributing towards poor signal. If you have that much extra wire, try running it in a longer path and not coil it all up in one place.
Old Aug 23, 2006 | 12:17 AM
kjg26's Avatar
kjg26
if instead of coiling it up could i just run it up and down the bed a bit. run it back towards the rear bumper then make a u-turn and back to my antenna? or will i have to go buy a 15 ft cable instead of the 20?
Old Aug 23, 2006 | 05:10 PM
Alter Ego's Avatar
Alter Ego
the 5 feet under your seat won't hurt you, typically absolute cable lenght only matter on the dual setup. where as if you have the big funky T connector, please if you can go to a cb shop and have a cable made proper tuned lengths. something for everyone to keep in the back of your mind when you put everything in. every connection that you put inbetween the cb and the ant (minus amps) will remove some part of your power and reception. ie the more small pieces of cable you joint with connectors the worse your signal typically is. 1 cable is always best, when you buy them in a package they are typically close to being tuned.
Yes that big T could be part of your problem. any of you guys that are really good, you can tune your radio from inside the radio. also bump up the power a little. same thing goes for you guys with amps. the amp doesn't always like 4-5 watts of input, sometimes the work better with 2-3 and the radio can be tuned internally to impedence match the amp for better sound quality and xmit/rcv power.
Old Aug 23, 2006 | 05:49 PM
kjg26's Avatar
kjg26
as of right now i have one single 20 ft RG58 cable running from the radio to the antenna and i can't get it tuned. not at all. what size wire should i use to ground my mount to the frame. it's on my tool box which attaches to the bed with 4 screws. doubt it has a good ground. i used a 16 gauge wire but i don't think thats nearly enough
Old Aug 23, 2006 | 06:00 PM
George Frasier's Avatar
George Frasier
Smile CB Tuning
It hasn't been specificlly mentioned,but, electrical length is important-to-critical.
Physical length and appearance is a matter of choice/taste. Most dual setups come with a dual cable ready to install. Many truck stops have a CB shop nearby - some, in the same building. Sometimes a shop will disconnect one antennae to tune the other "twin", connect it and disconnect the other, and tune it. Most will be adequate out of the box. Some CB's have an SWR meter so you can do it URself. Not much adjustment is needed. Some motorcycles use shielded coax lead-ins - with a speaker inside the helmet - it sounds like a machine gun going off when each cylinder fires.
sirsofus
Dec 9, 2013 03:21 PM
skirk55
Nov 21, 2006 06:17 PM
THEBOOGIEMAN
Offroad & 4x4
Mar 26, 2006 10:22 PM
taxabel
66
Oct 10, 2004 12:59 AM
rver
All Things Towing
Sep 11, 2004 11:09 PM
