Need headers for my 77
Old Aug 21, 2006 | 05:16 PM
77f150xlt429cid's Avatar
77f150xlt429cid
Question Need headers for my 77
I am in the process of putting a 71 429 cid in my 77 F150 and just wanted to ask if anyone on FTE has a set full length headers they want to sell or know where I can get a set to fit. I have removed the air/heater box and blocked the hole off for extra clearance and I am also removing the front fuel tank to give more room for headers and shorty duals. If anyone can help me out please reply asap.
Old Aug 22, 2006 | 12:10 AM
Dustin1690's Avatar
Dustin1690
Did you try the classifieds on the site here??? that would be a good place to start
Old Aug 22, 2006 | 06:42 AM
1ole4d's Avatar
1ole4d
Also, we would need to know if the truck is a 2wd or 4wd.
Old Aug 22, 2006 | 10:53 AM
Blown 331's Avatar
Blown 331
Get L&L's for sure. I have the fender well exit headers on my 77 and they are awesome. It says you need a body lift but you don't, I had to slightly trim my inner fender wells. With the fender well headers you don't have to get exhaust made/bent for it because everything is on the outside of the frame you just bolt up straight pipe and mufflers, no bending required.
Old Aug 22, 2006 | 09:11 PM
77f150xlt429cid
The truck is a 2wd. As far as the fenderwell headers go for racing in stock or trophy class the exhaust has to be run under the truck in the stock location, whether it be single or duals.
Old Aug 22, 2006 | 10:14 PM
77460ford's Avatar
77460ford
You could try "Stans Headers", it's a tri-y design that fits in the frame rails and very well built. He carries a set for 2wd and you can order your choice of flange thickness. Good people to deal with and excellent fit, in my case it was 4wd.
Old Aug 22, 2006 | 11:05 PM
Mil1ion's Avatar
Mil1ion
I haven't checked what my 77 with 460 has hooked up to the manifolds Yet,but it does have dual exhaust 2" straight pipes coming out the back.
Old Aug 23, 2006 | 03:18 PM
77f150xlt429cid
Do you have a web address for " Stan's Headers" so I can contact them, I need to hurry up a little, the races are on Sept 10 and I havent evnen put the motor or trans in the truck yet. I just picked the tranny up today from the tranny shop. I'm hoping to get most of it together this weekend.
Old Aug 23, 2006 | 04:05 PM
77460ford's Avatar
77460ford
Sure do; http://www.stans-headers.com
Old Aug 23, 2006 | 04:26 PM
76JDGREEN's Avatar
76JDGREEN
blown 331 , is there still room to do dual shocks after you put your headers on?
Old Aug 25, 2006 | 09:51 AM
Blown 331's Avatar
Blown 331
I just have single shocks on mine but I can take a look at let you know what I think. I can prob even snap a pic with my phone.
Old Aug 26, 2006 | 01:37 AM
LxMan1's Avatar
LxMan1
Any header for a 2wd 73-79 with a 460 will work on the 429. I have Dynomax headers on my 77.
