carb problems
Old Aug 21, 2006 | 03:15 PM
matt123's Avatar
matt123
Question carb problems
I need help! I have a 79 F-150 that has aprox 35K miles on rebuilt 351m. Just had new carb installed and when you step on the gas at any rpm it has a bad stall before picking up, otherwise runs fine. The new carb is a reman of the original 2V. Would like any help I can get.
Thanks in advance
Old Aug 21, 2006 | 03:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Aug 21, 2006 | 04:23 PM
76supercab2's Avatar
76supercab2
What kind of carb? Make? Model? Number of barrels?
First guess is the accelerator pump shot is wrong. Probably not enough. Do you get e puff of black smoke out the back when you mash the pedal? If you do the engine is going too rich. If not then it's probably leaning out. Look down the carb throat and move the throttle linkage. You should see raw gasoline squirt into the primary barrels when you do that. It could also be that the accelerator pump linkage is misadjusted, or that the pump cam is worn.
Old Aug 21, 2006 | 05:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Duplicate threads merged.
