What Chip should I order??
Old Aug 20, 2006 | 04:50 PM
rsyauto's Avatar
rsyauto
I have a stock 02 7.3 4x4 and would like to gain some hp without doing a bunch of upgrades. Can I use a chip without additional mods? Thanks
Old Aug 20, 2006 | 04:57 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
for a short answer, no. you need a recommended group of mods so you can safely run a chip. not that a chip WONT work on a stock truck, it certainly will. however the exhaust temps will SKYROCKET and you can easily burn up your engine. to start off, you need a set of gauges. the standard three on the a-pillar is boost, EGT and transmission temp. now you know what temps you are running, you will see that you are getting very hot, very fast. the next two mods should be done together, which is exhaust and intake. that is about all you need to safely run a chip, however you will have a mushy feeling transmission. so, a valve body is recommended.
as for the chip, a DP tuner chip is the hot ticket it seems now. im upgrading to one after a few other mods.
Old Aug 20, 2006 | 04:59 PM
ponch37300's Avatar
ponch37300
dp tuner has the best chip. You can visit his web site and give jody a call and he is great at talking with you and seeing what will be best in your situation, he knows his stuff. Most people at least to an intake and exhaust to let there truck breath better. The exhaust you can get for 350 and intake for around 20. Also you should have some gauges, egt, boost, and trans temp. They are about 300 for everything. Do some searching on here and you will find everything you need to know about all this stuff. Good luck
Old Aug 20, 2006 | 05:15 PM
rsyauto's Avatar
rsyauto
Where did you get the International Badges? Very nice..Also how much? Thanks
Old Aug 20, 2006 | 05:17 PM
rsyauto's Avatar
rsyauto
When you say intake, do you mean air intake?
Old Aug 20, 2006 | 05:28 PM
PowerstrokeJunkie
badges.. me? i got them at fordemblem.com, here is the page. http://www.fordemblem.com/results.ph...=International
about $50 shipped. excellent quality and awesome looks.
the intake, yes i mean the filter. some guys replace their stock leaky airbox with an AIS from Ford that has a cool-designed filter, for about $200 and the new airbox. most of us guys just use a huge open-element filter that is $20, and it lasts forever. here is a pic of it.
wow, that pic is OLD.
Old Aug 20, 2006 | 05:38 PM
rsyauto's Avatar
rsyauto
Thanks, I am running the Kand N in stock box. Should I still change?
Old Aug 20, 2006 | 05:41 PM
CC'sDad's Avatar
CC'sDad
I would change to what strokin has if I where you, that K and N lets an amazing amount of dust through. With that much filter area the 6637 flows better.
Old Aug 20, 2006 | 05:42 PM
PowerstrokeJunkie
yes, defanitely. leaky stock box+ leaky filter isnt very good. these engines consume the equivalent of 20,000 gallons of air for every gallon of fuel. i dont want an oiled filter in my engine. that super vacuum produced in that intake tube has the ability to pull off the oil from the filter if oiled too heavy. with the oil comes the dirt.
Old Aug 21, 2006 | 10:12 AM
Car_nut57's Avatar
Car_nut57
FTE *******
You could use a Banks Git-Kit, which is a 45hp chip and 4" exhaust. Anything more than that and you need to do gauges, air intake, comp. wheel etc.
Old Aug 22, 2006 | 11:25 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Dp Tuner......you Will Not Regret
Old Aug 22, 2006 | 12:42 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
4x4 IS RIGHT!!
Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret, Dp Tuner......you Will Not Regret
