e4od problem
Old Aug 20, 2006 | 01:45 PM
knapikmichael's Avatar
knapikmichael
Exclamation e4od problem
i have a e4od tranny in my 94 diesel i want to put in a c6 i do a lot of off roading and i dont need overdrive any advice on both trannys
Old Aug 20, 2006 | 01:47 PM
knapikmichael
lookin 4 a replacement or a new one need advice
Old Aug 20, 2006 | 01:48 PM
knapikmichael
i need some help on this matter
Old Aug 20, 2006 | 10:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
knapikmichael,
Welcome to FTE and the IDI diesel forum.
The C6 is the strongest automatic that was used behind the diesel.
You should be able to find one in a salvage yard rather cheaply.
The C6 was vacuum controlled so you will also be doing some vacuum line work.
When you call the salvage yard, you need a C6 that was originally behind a diesel engine, 6.9 or 7.3.
I am not much on automatics, but there are several other people here that can answer more of your questions.
