tools for king pins
Old May 9, 2002 | 09:59 PM
63f2504x4man's Avatar
63f2504x4man
tools for king pins
[updated:LAST EDITED ON 09-May-02 AT 11:00 PM (EST)]hey....ive got a 63' f-250 4x4 that needs king pins and i dont know the proper tools to use on them if anyone could help me out i'd appreciate your time and efforts thnx.......
Old May 10, 2002 | 01:52 AM
62stepside's Avatar
62stepside
tools for king pins
well, being a 4x4 I'm confused about the kingpins... I've never owned a ford 4x4 that old, so I could be wrong... (wouldn't be the first time ) I don't think a 4x4 has kingpins... On my '62 (4x2) the straight axle has kingpins... or are the equivalant parts on a 4x4 called kingpins? The only 4x4 experience I have is on my '79 c@#vy blazer... Enlighten me
Tyson
Old May 10, 2002 | 07:11 AM
44dwarf's Avatar
44dwarf
tools for king pins
They are called many things on 4x4's. Some names are King pins, Trunin bearings, King bushings. Basicly there a short pin with a 4 bolt flange on the end.
I'll post info when i get home.
44Dwarf
Old May 10, 2002 | 03:50 PM
bhabben's Avatar
bhabben
tools for king pins
63f2504x4man,
Does your front axle have the enclosed knuckles? If so, this is easier than it looks. If not, ignore the rest of this post. Dana axles with enclosed knuckles used 'trunion bearings'. All they are is a pair of tapered bearings and cones. The bearings are located under the metal cover plates where you would think 'king pins' would be located. The only tricky part is that they have to be shimmed for preload. But, I've gotten by just making sure that I got Timken bearings to replace the originals and put it back together with the original shims in the original places.
A quick way to check the condition of the bearings is to jack up the truck under the axle housing and try and move the wheel up and down. There should be zero slop at the trunion bearings (king pins). Typically what happens is the felt seals wear out allowing lube out and dirt and moisture into the joint. The trunion bearings are lubed by whatever is or is not in the joint. A new set of felts (seals) are probably needed also. You may have to grind, sand, polish the bells on the axle housing to get them to seal.
Holler if you have any other questions.
Adios,
Brett
Old May 10, 2002 | 09:56 PM
66ranger's Avatar
66ranger
tools for king pins
