Charging problems
Old Aug 20, 2006 | 03:17 AM
67f100's Avatar
67f100
Charging problems
I have a 97 Expi. with the 5.4. I am having charging problems. It comes and goes. It has a 3 year old Napa battery. I clean the battery posts and cables and a week later they are very corroded again. The volt meter is jumping up and down. It seems to charge normal at higher RPM, like above 2500, let off the gas and the needle drops. I clean the cables and it seems to do ok for a while and then it,s back, any Ideas?
Old Aug 20, 2006 | 08:49 AM
ronk1969's Avatar
ronk1969
sounds like alt is going bad
Old Aug 20, 2006 | 02:11 PM
67f100's Avatar
67f100
When I clean the corrosion off it seems to charge fine, for a while at least. But the corrsion (and I mean a lot) come back in about a week to ten days. Then charging problems, needle starts doing back flips from normal down to the bottom. Does that gauge monitor just the alternator or will battery problems cause it to act funny.
Old Aug 21, 2006 | 11:04 AM
slc10844's Avatar
slc10844
Try replacing the battery. That will probably take care of the corrosion problem.
