I have a late 99 f250 and need to put on a new front axle, so I went to the junt yard and found one for a real good price but it's out of an early 99 f250.
The axle that I got has the same gear ratio but if I look at the web site to search for parts and look for this axle it gives me the option of 10mm hub flange or 13mm hub flange and supposably the one I got from the junk yard had 10mm hub flange and I have 13mm, so I wanted to know if I can still use the axle.
