Code problem missfire P0171/P0330 Need Help
Old Aug 20, 2006 | 12:18 AM
BigDogg715's Avatar
BigDogg715
Unhappy Code problem missfire P0171/P0330 Need Help
<HR style="COLOR: #ffffff" SIZE=1> <!-- / icon and title --><!-- message -->
I have a '05 XLT Screw 11,000 miles and Just wondering if anyone else had the same problem. I noticed the truck not running right like it was missfiring not bad but noticable. Then today it really got worse the check engine light flickered on and off then when I checked it with my meter and it came up with a P0171 Lean fuel, and a P0330 misfire Cylinder 3. I'm running 87 octane in right now. I'm new to Ford products being this is my first truck and my first Ford, just want to know what might of caused this misfire in the engine. Please help.
Old Aug 20, 2006 | 10:03 AM
red dog's Avatar
red dog
I talked to a guy the other day and asked if he's had any problems with his 05 FX4 screw, he described your symptoms and said he had 3 injectors replaced.
He has the 5.4 and i'm assuming thats what you have?
Old Aug 20, 2006 | 10:34 AM
BigDogg715's Avatar
BigDogg715
Yep I have 5.4l. I did a little homework and found a TSB on this issue.
Technical Service Bulletins Summary
Make: FORD
Model: F-150
Year: 2005
Type: TRUCK
Service Bulletin Number: 041601
NHTSA Item Number: 10018745
Summary Description:
WDS COP KIT DIAGNOSTIC TIP - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING. *TT
Taking it over to the dealer to fix the problem, Thought it might of been something I did to the truck to cause the problem, guess not.
Old Aug 21, 2006 | 07:14 AM
Bob Jusnes's Avatar
Bob Jusnes
The COP ignition system would not cause the lean code, I have a feeling it could be the injector as well. Make sure the dealership knows that it was running lean as well, and let them figure out the problem on their own.
Old Aug 21, 2006 | 12:50 PM
BigDogg715's Avatar
BigDogg715
Just got the truck back from the dealer and you guys were correct it was a bad fuel injector. Thank's for all your help.
daveplot
Jun 20, 2022 11:13 AM
acm05fsu
1997 - 2003 F150
Dec 26, 2019 02:24 PM
Frank Vila
1997 - 2003 F150
Apr 13, 2016 11:28 AM
Jason01
Modular V8 (4.6L, 5.4L)
Dec 30, 2008 09:37 PM
BigDogg715
Aug 21, 2006 01:58 PM
