engine fans revisited
Old Aug 26, 2006 | 10:23 PM
Zip's Avatar
Zip
I just replaced mine today as it was locked up. It actually had me thinking that I had transmission issues. I paid just over $100.00 for the clutch. Huge difference.
Old Aug 27, 2006 | 07:33 AM
cangim's Avatar
cangim
Where did you get your clutch at?
Old Aug 27, 2006 | 12:11 PM
Zip's Avatar
Zip
I'm from Canada. I got mine at a local lordco which I guess is one of our major parts stores. Napa gave me a price of just over $150.00.
Old Aug 27, 2006 | 06:13 PM
bushman31's Avatar
bushman31
The new clutch I have seems to stay engage until the engine is well into the normal temperature range, as I can hear the fan roaring until it warms up. When the engine is cold it still has the same resistance, then after driving the truck the fan is a lot easier to turn. This may be because the fluid in the clutch is cold, making it stiff.
Ron W.
Old Aug 27, 2006 | 07:24 PM
nlemerise's Avatar
nlemerise
Here is a pretty good article on how fan clutches work and on the second page of the article there is a simple test for checking them...interesting they mention our trucks in the article: " A few late-model pickups and SUVs, such as Ford diesels and the Chevy TrailBlazer and others with the 4.2-liter inline Six, have an electronically controlled valve for the fan clutch. In these vehicles, the silicone fluid doesn't drain back overnight, so the fan may barely spin on a cold engine. It could take a brief drive to get it to declutch."
Neal
http://www.popularmechanics.com/automotive/sub_care_sat/1772922.html
Old Aug 27, 2006 | 08:01 PM
bushman31's Avatar
bushman31
Thanks Neal for that article. After getting the clutch I have been checking it, and I really don't know why! After letting the truck idle, to cool down the turbo, I check the fan and it turns fairly easy. As the engine cools off, several hours, it stiffens back up. It will remain engaged until the engine gets up into the normal range. Kind of weird, but at least it isn't remaining engaged. Also, I have less that 15 miles on it and it is all city streets. Might take a little highway driving to loosen it up a bit.
Ron W.
Old Aug 27, 2006 | 11:08 PM
Mrgeoff's Avatar
Mrgeoff
Originally Posted by bushman31
I got a rolled up newspaper and tried to stop the fan with it. This was suggested on a previous thread. Well, it didn't slow down the fan a bit, but now I am out of a newspaper. This is telling me that the clutch is engaged when it shouldn't be, and could account for the slight, but noticable, lack of response from a dead stop.
Now that was stupid, why didnt you just use your hand. When they go out they lock up and never release again. Just replace fan clutch and be done with it.
Old Aug 28, 2006 | 07:52 PM
bushman31's Avatar
bushman31
I did replace the fan clutch, however apparently it has been replaced with a defective clutch. I talked to the mechanic that replaced it, and told him about the fan being engaged until the engine gets to normal operating temps then disengages. Said it was defective, and to bring it back in.
Ron W.
Old Aug 29, 2006 | 08:04 AM
Kwikkordead's Avatar
Kwikkordead
Bushman he is right. Normal operation is to be engaged for only a few hundred yards in the morning, then it loosens up until things get too hot and it needs to engage.
Old Aug 29, 2006 | 08:45 AM
nlemerise's Avatar
nlemerise
Yup...that was in the article I linked to: " A few late-model pickups and SUVs, such as Ford diesels and the Chevy TrailBlazer and others with the 4.2-liter inline Six, have an electronically controlled valve for the fan clutch. In these vehicles, the silicone fluid doesn't drain back overnight, so the fan may barely spin on a cold engine. It could take a brief drive to get it to declutch."
Old Aug 29, 2006 | 06:44 PM
bushman31's Avatar
bushman31
The warranty company forced the dealership to put on a NAPA clutch. $230 versus $360. I have always had bad luck with NAPA parts, and another shop had even more nice things to say. I took the truck back to the dealership and told them to put on a Ford clutch and I will pay the difference. This clutch was also causing the fan to be LOUD! Louder than a semi truck, couldn't believe. Hopefully this will be the end of it.
Ron W.
PS. I really want to thank everyone on this list. Just hoping one day someone will ask a question I can answere.
Old Aug 29, 2006 | 08:49 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Tenn01PSD350
Good deal Bushman. I still stand by my earlier statement. It's a fan working against 200+hp and well over xxxxTQ.
The stock fan with the clutch fully engaged moves something like 7500 cfm. That, from what I understand, equates to almost 50 horsepower. Definitely enough for you to feel the difference.
Old Aug 29, 2006 | 09:16 PM
  #28
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
wow, 50 horsepower! i think a flex-a-lite is in my future. is it still moving "near" that much air when you are just cruising around? i thought it just freewheeled at the speed of the air passing over it as you are going down the road??
Old Aug 29, 2006 | 09:22 PM
  #29
cookie88's Avatar
cookie88
FTE Emeritus
It never freewheels. As was mentioned earlier a viscous coupling always has "some" resistance. It's just substantially less when it's hot.
Old Oct 26, 2006 | 08:57 PM
  #30
truckguy300's Avatar
truckguy300
My 5.4 fan runs constantly. Even when 0 degrees outside. Never hear it. But when it's that cold shouldn't the fan not turn engine speed? The truck is an 02 F-250 Superduty and the fan is hudge, shouldn't I be able to hear it or feel it?
