I am about to hit 100k any suggestions on what maintenance I should do at this interval would be appreciated. The truck is 2002 F-250 4x4 light towing mostly highway driving in the the Arizona heat. Ford recommended maintence is very limited with information. Thank you!
Flush the coolant system,replace tranny ATF, Replace differential fluids, change out/bleed the brakes(once every 2 years),change transfer case fluid fluid, load test batteries(depending on age).
Some items that come to mind.
Nut
yep, PSnut has a good list going. i will add flushing the Powersteering/hydroboost system, and greasing the wheel bearings and lubricating the autolock vacuum hubs, if you have the **** on the dash for 4x4.
yeah...good stuff too....maybe a visit to Guzzle's maintenance stuff: LINK
Nut
Thank's for all the input and putting the question in the right forum!! Guzzlers page was really helpful and I can't wait to do some of the projects he talks about.
