2.5L iginiton question
Old Aug 19, 2006 | 10:02 AM
mfriesen's Avatar
mfriesen
Does anyone know if the EDIS system on the 2.5L (1998) work like the 3.0 and 4.0's that use reverse polarity? I want to change plugs and would like to know if I need to spend the extra on the double platinums.
Old Aug 19, 2006 | 10:59 AM
jimdandy's Avatar
jimdandy
Smile
Yes. Ford DIS & EDIS uses the "waste spark" system in most engines. The Ford Lima engines, 2.3L and 2.5 OHC have two plugs per cylinder, where the others have a single plug per cylinder. jd
Old Aug 19, 2006 | 11:00 AM
RangerPilot's Avatar
RangerPilot
I'd think so.
Use Motorcraft or Autolite plugs, nothing else, and use only those reccommended in your owner's manual.
Old Aug 19, 2006 | 11:38 AM
mfriesen's Avatar
mfriesen
I think I will spend the extra and money and get the double platinum plugs. After looking were they are located, I won't want to do this for a long time, and with double platinums I shouldn't. I pulled one plug to see what they looked like and I tore the boot off the wire just getting it off. So time for new wires also. At 124K it is probably time for that any way.
Old Aug 20, 2006 | 12:32 AM
budman-mo's Avatar
budman-mo
Funny thing.....I am doing this same thing now on a '98 2.5.
Yes on Moto platniun, I have had good luck (100K). I am taking out some Bosch with 50k on them, not so good.
The real funny part is mine has aprox 225k on it with orig wires (they are dated, 1998).
I thought this time I would do the wires too, I checked the resistance on them and the OLD wires have less resistance than the NEW Motocraft wires???
Go figure.
Old Aug 20, 2006 | 12:47 AM
mfriesen's Avatar
mfriesen
Well changing plugs on the driver's side is a real pain. All together I ended up having 5 wires pull out of the boots. The plugs that I replace were Autolite Platinum. I checked the gap on a few .052-.059. While I was dirty and struggling with hard to reach parts I replaced the PCV valve. Also cleaned MAF sensor, and changed the fuel filter.
Truck runs good, I had noticed that when taking off or on some shifts I heard pinging, now that is gone. Now I just need to figure out the clunking noise from the front end.
andyman1961
Mar 7, 2011 07:48 PM
k-l.kelley
Engine Swaps
Oct 4, 2004 11:01 AM
kenwood599
Jun 19, 2004 11:22 AM
surelly09
Nov 20, 2003 08:10 AM
