Greetings
My name is Jonathan and I'm new to these boards. I just bought a '64 F-100 Long Bed built in San Jose. 223 3 spd, nothing fancy. Theres been a half-assed resto effort on it before, and its got lots of new or repaired stuff, and lots of worn out/half witted stuff. Anyway, I have several questions. Lets start with engine number, and we'll get to my starter armature tomorrow. Heh. Just for grins, it was built in August of '63, color code M (Wimbledon?) Trans A, Axle 12, Body 081 (can anybody define 081 for me?), and DSO 72.
Engine # EBP-6015-?maybe D or 0 Its the P thats throwing me off a little bit. The 64 Ford Truck Shop Manual calls for EBR, EBS or EBT. Its a decently running engine when it runs, but I'm wondering where it came from. The tranny # is C3AR 700B-E.
I look forward to posting with you fellas....
With that,
Color Code M = Corinthian White ('60 - '63)
Trans A = Ford 3 speed
Axle 12 = Ford 9"- check the tag and post the numbers to decode it for the exact ratio.
Body 081 = Closed Cab (the 0 means nothing, but closed cab means it wasn't delivered as an open driveaway to a customizing place.)
DSO 72 = ?
Congrats on owning one of the classiest trucks Ford ever made!
DSO 72 means the San Jose district. It means Domestic Special Order. If a Ford was specially ordered from the factory, it would be noted in this slot with an order number. If its just a regular production unit, it just carries the district number it came from.
My color question is because I saw somewhere on the web, that '64s with color code M were 'Wimbledon', but my manual calls for 'Corinthian'. Theres still a bit of good paint in some nooks and crannies, which I could probably get a decent enough look at to match. But paint is a long long way away....so I'm not to worried about it just yet.
I think that its got a 128 inch wheelbase is pretty cool. Theres seems to not have been many of those produced. Its still got its original long bed, but it was used as a campertruck for some time, it seems, and the beds pretty well beat up, and poorly bondoed in one place.
I'm pretty darn psyched to have such an early produced unit. Being built in August of '63, it was probably sold in late '63 as a '64 model. The older the better, as far as I'm concerned.
If its #1184 off the line, I'm wondering how many of these trucks rolled off in a day....50? 100? 500?. Could it have been made in the first week of production? Hmmm. Just an interesting thing to think about, I suppose.
I've got the dealer manuals as well, and they can help fill in some of the blanks. I'll break this out for you:
F10 = F-100 series
J = Engine 223 ci 6cyl 114 hp@3600 rpm
R - San Jose Plant
446184 = August 63
Now on this date thing, the numbers were assigned in blocks to the month, whether they made that many or not. Depending on how many were made, yours could easily be in the early part of the month - or not.
M Color: According to the Paint section in the parts book, M meant Corinthian white up to '63. After that, it was known as Wimbledon White. I have seen many incorrectly refer to the earlier color as Wimbledon, when in fact is is Corinthian.
Your HP and RPM stampings seem to correctly reflect the engine J code.
DSO stands for District Special Order, and has nothing to do with the plant, but the special orders such as overseas, police, etc.
Check your axle for the tag, and post that info here if you've got any questions.
And, if I were you, I'd be just as psyched over having that truck too!
But that's all.
Sorry I cannot help more!
"Trucks built to Domestic Special Order have the order number and the District Code number of the district which ordered the unit stamped in this space, If the truck is a regular production unit, only the District code will appear."
Then, there is a column with District Codes, starting with 11, being Buffalo, and ending with 90-99 being Export. From this column, 74=Seattle; 90=Export; and 43=Rockford. I don't think that has anything to do with your truck.
It seems to me, though I'm no expert on this, that your truck may have been special order. Is there anything unusual or special about this truck? Color, or A/C or something?
J
Sound right?
Sorry it took me so long to realize what it was.
as A/C or custom cab,just a standard cab F100 4X4 4Speed(NP435)Long(128)wheelbase styleside.The only thing that seems different is that
it has a separate set of coil springs on top of the leaf springs.They
are short and look like they only contact the bed frame when the leaf springs compress about three inches
Thanks
Andy,Shasta Lake ,Ca.
Thanks
Hmmmm. My shop manual (for 1964, mind you) has an exploded illustration of the rear spring for an F-250 4 wheel drive, which it says is typical of the F-100 as well. There are no coil springs to be found, there are however auxilliary leaf springs, but I'm not sure from the diagram exactly where they are in the suspension. I suppose that the coil spring could be a specially manufactured addition from the factory, but....who in their right mind would order something like that from the factory in 1966, and nothing else? With the large number of 4x4 shops around, it could easily be an aftermarket replacement part, or repair.......Or maybe not.
If the truck really is a special order, theres gotta be some record of it somewhere. Maybe Ford has a record of it, or could give you some good leads.
Jonathan
Mythical State of Jefferson
>it refers to your Trim Scheme. O stands for black vinyl,
>with a foam cushion in the seat.
>Sound right?
Are you sure its an O and not a zero? my body code is a 381 and its a 64 as well.
I can't comment on the interior trim, as, well, the seat frame and springs are all that are original, but its been hippied up real good with a foam cushion and an inexpensive ugly brown seat color. I'd love it to be black with a foam cushion. I'm thinking it may have been red though, from some remnants I've seen.
I'll get around to posting a picture of the interior in my gallery. Right now I'm doing clutch and ignition relay stuff.
Anbody know where to get a good, at least original looking air cleaner for a 223 1V carb?
J
