CCV MOD need a little help!!!
Old Aug 17, 2006 | 08:36 PM
dt444e's Avatar
dt444e
I was wondering if someone could make me up a parts list on what I would need to make this ccv mod work...Also I have four inch exhaust a K&N air filter Banks six gun tuner I was wondering if there is a good chip that mirrors banks big hoss. Reason for the Banks hoss is because this can be stack with the six gun.
Old Aug 18, 2006 | 05:26 PM
trike1946's Avatar
trike1946
I assume you want to just get it away from the intake. If you do a search you will find a lot about it. I looked at mine the other day, and it looks like you just need a long piece of rubber hose to drop it out the back, and some wire ties. You have to plug the hole in the intake also. Do the search for better info than what I can give you.
Old Aug 20, 2006 | 07:33 AM
Cuda_jim's Avatar
Cuda_jim
Take some time and fill out your signature, this will help the guys here answer your questions more effectively. I see you have a 2000. Although your question pertains to trucks in this forum too, you'll get better info on your truck in the proper forum.
You should post your questions here:
https://www.ford-trucks.com/forums/f...splay.php?f=31
