Trailer brake setup
Old Sep 7, 2006 | 06:09 AM
  #31
al_e._gator's Avatar
al_e._gator
I have the 04 electrical shop manual. The wiring info is in there, I'll try to post it tonight. Meanwhile, I think I already posted it in one of the earlier discussions on this topic so you may be able to find it on your own.
Old Sep 7, 2006 | 07:27 AM
  #32
subford's Avatar
subford
This is from the 1996 E-Series Manual if this is what you are looking for.
Trailer Towing Package Wiring
Trailer Wiring Relays
There are no relays which are standard for the trailer towing class I package. The trailer towing packages may incorporate the auxiliary battery relay or the trailer battery charge relay, but not both.
The following relays are standard for the trailer towing class II package:
Trailer running lamp relay
Trailer backup lamp relay
Trailer Wiring Feed Wiring
The class I trailer wiring is fed by the following circuits:
Circuit 52 (Y) -- Left turn
Circuit 64 (DG) -- Right turn
Circuit 962 (BR/W) -- Park/headlamp signal
Circuit 206 (W) -- Ground
The class II trailer wiring is fed by the following circuits:
Circuit 963 (BK/LG) -- Reverse signal
Circuit 49 (O) -- Auxiliary battery feed
Circuit 43 (DB) -- Brake
Diagram 1
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring1.gif
Diagram 1 Key
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring1Key.gif
Diagram 2
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring2.gif
Diagram 2 Key
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring2Key.gif
Diagram 3
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring3.gif
Diagram 3 Key
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring3Key.gif
Diagram 4
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring4.gif
Diagram 4 Key
http://i54.photobucket.com/albums/g91/subford/Electrical/1996%20Van%20tow/Wiring4Key.gif
I hope this helps.
blue924.9
17
May 24, 2015 06:24 PM
idesign
Mar 18, 2011 11:01 AM
jonnysteals
All Things Towing
Jun 29, 2007 01:16 AM
J.A.F.E.
Oct 11, 2006 11:55 PM
trike1946
All Things Towing
20
Jan 5, 2005 09:13 PM
