My truck appears to be leaking fuel out of the water/fuel separator, possibly the O-ring that seals the Yellow release valve.
It was leaking so I opened and closed the valve. Fuel wouldn’t stop draining at that point. I had to open and close the valve several times to stop the steady flow. No it just a steady drip.
Does changing out the O-ring sound like the right thing to do? Is this something I should attempt myself or should I take it to a shop?
<O</O
I'm not sure that Home Depot is selling o-rings like they used to, in small plastic bags. The Danco display seems to have disappeared from most of their stores.
