1978 - 1996 Big Bronco
02 sensor ?
Old Aug 16, 2006 | 10:15 PM
gener46's Avatar
gener46
02 sensor ?
I have 2 codes. p0133 & p1131, I think it telling me that to replace the o2 sensor. One says slow response, and the other says insuff. switching & sensor lean. Both say bank 1 sensor 1. Am I correct. I have 80k on the truck, had since 39k and don't think they were every replaced. Just put in a new PCM, something to do with its memory. Now I'm getting codes. Any help would be greatly appciated.
96 Bronco EB 5.8
Old Aug 17, 2006 | 03:52 PM
Fishallot's Avatar
Fishallot
DTCs P1131, P1151, P1132 AND P1152: UPSTREAM HO2S(S) NOT SWITCHING. DTCs P1130 AND P1150: FUEL SYSTEM NOT SWITCHING AT THE ADAPTIVE LIMITS (RICH OR LEAN)
Diagnostic Trouble Codes (DTCs) P1131 bank (1) (Cylinder #1) and P1151 bank (2) indicate the fuel/air ratio is correcting rich for an overly lean condition. The HO2S voltage is less than 0.45 volt. DTCs P1132 bank (1) (Cylinder #1) and P1152 bank (2) indicate the fuel/air ratio is correcting lean for an overly rich condition. The HO2S voltage is greater than 0.45 volt.
DTCs P1130 and P1150 indicate the fuel control system has reached maximum compensation for a lean or rich condition and the HO2S is not switching.
DTC/HO2S Reference List
-- HO2S-11 = DTCs P1131, P1132 and P1130
-- HO2S-21 = DTCs P1151, P1152 and P1150
Possible causes:
Fuel system
-- Excessive fuel pressure.
-- Leaking fuel injector(s).
-- Leaking fuel pressure regulator.
-- Low fuel pressure.
-- Contaminated injector(s)
Induction system
-- Air leaks after the MAF.
-- Vacuum leaks.
-- Restricted air inlet.
-- PCV system.
-- Fuel purge system.
-- Improperly seated dip stick.
EGR
-- Leaking gasket.
-- Stuck open EGR valve.
-- Leaking diaphragm.
Base engine
-- Oil overfill.
-- Cam timing.
-- Cylinder compression.
-- Exhaust leaks before or near the HO2Ss.
l Check air intake for leaks, obstructions and damage.
l Check air filter, air filter housing for blockage.
l Verify integrity of the PCV system.
l Check for vacuum leaks.
l Are there any of the above concerns?
Yes
SERVICE as necessary. RERUN «Quick Test».
No
GO to «H42».
