injectors?
Old Aug 16, 2006 | 06:07 PM
danny_g_76's Avatar
danny_g_76
injectors?
I took off my plenum injectors and throtle body. I went to put them back on today. The injectors are leaking. The back passenger and the second one back on the driver side. How do Install them so i dont have leaks? I dont want to blow up.
Thanks Dan
Old Aug 16, 2006 | 07:35 PM
lostin90s's Avatar
lostin90s
Did you swap in new o-rings ? I lube mine when I install . Usually no problems . But I did mine 2 weeks ago and have a leaker too. O well another weekend of on play.
______________________________________
94 F150 4x4 super cab long bed Maf 302 at
Old Aug 23, 2006 | 11:28 AM
Old_Paint's Avatar
Old_Paint
I wouldn't even bother doing the job unless I had a set of new o-rings to go in. 10 time outta 9, you'll nick them when pulling them out of the intake or the fuel rail. Unfortunately, I've also learned the hard way, if you're gonna pull 'em, CLEAN 'em. That's a lotta work to go through only to find you still have a lean-burn miss. Check E-Bay for mrinjector. They offer full kits including new pintle caps to go on the injectors, at a reasonable price.
Old Aug 23, 2006 | 04:46 PM
danny_g_76's Avatar
danny_g_76
thanks i allready have it back together. New rings it is sealed no leaks. Thanks
dan
