1978 - 1996 Big Bronco
burning antifreeze?
Old Aug 16, 2006 | 07:31 AM
HUCKSTER-USA's Avatar
HUCKSTER-USA
Question burning antifreeze?
sometimes when i reach in and start my trk and do a walk around i'll smell antifreeze. the overheating type smell, seems like im burning it, could it be a head gasket? its been pinging when i pull a hill on the hwy. no performance loss and antifreeze level hasn't gone down since i topped it off last wk. and the oil is clean
Old Aug 16, 2006 | 09:55 AM
poffutt's Avatar
poffutt
don't assume the worst. If you smell the atifreeze burning then I would think that you have a small leak from one of your hoses on to you intake manifold. look at all your hoses closely and look for discoloration from a leak that is evaporating as soon as it hits the hot engine.
Old Aug 16, 2006 | 09:57 AM
b4hntn's Avatar
b4hntn
Have you heard a babbling brook sound from behind the glove box? It took a year from hearing the sound to finding coolant on the ground when the heater core leak got bigger. Heater core is an easy replacement project. Of course hoses, clamps, water pump and radiator should also be considered. You could have a small leak that drips under pressure, evaporates, then you smell but do not see when cold.
Old Aug 17, 2006 | 11:11 PM
HUCKSTER-USA
thnx just got into town gotta chk it out, the smell is instnt, havent seen any leaks.
Old Aug 18, 2006 | 09:07 AM
tom2131968's Avatar
tom2131968
I would suspect crossover pipe and heater hoses first. Makes sure the clamps are tight too and that they are not stripped. I had one on a heater hose that looked and felt tight (just not tight enough) but was stripped and would let just a bit of coolant seep when the engine was hot.
Spidsns
Oct 1, 2016 12:09 PM
RLTotten
1997 - 2003 F150
Jun 11, 2016 10:43 PM
92F150Stpsd
15
Mar 7, 2011 04:40 PM
ValkyrieVixen
1983 - 2012 Ranger & B-Series
Nov 2, 2007 09:41 AM
wolftan
18
Mar 11, 2007 07:13 PM
