Sponsored by: Innova
e-brake light locate
Old Aug 15, 2006 | 09:25 PM
georgeg's Avatar
georgeg
how i do bypass jensen vm9511ts dvd
Old Aug 15, 2006 | 10:13 PM
xtrm1stang's Avatar
xtrm1stang
I'm not sure the exact operation of you head unit, but they make a control box that will send the proper signal to the head unit, check you local stereo shop, i believe its called a pak7 or something like that. I installed one on my pioneer HU, works great
Old Aug 16, 2006 | 12:40 AM
FTE Trigger's Avatar
FTE Trigger
Welcome to FTE georgeg!!
I think your looking for the "switch" that tells the dash brake lite to come on, thus sending a signal to the DVD unit that its "Safe" for you to play a movie or turn the TV tuner on?
It should be a 2-wire connection (Circuit 0162; Assembly 12A581) Wire color you are looking for is LG/RD
Old Aug 16, 2006 | 12:46 AM
FTE Trigger
Or the ground right next to it depending on the sequence involved with that particular unit.
Old Aug 18, 2006 | 12:39 PM
CBFryman's Avatar
CBFryman
Usually just a (+) 12v or (-)12v...find out which it needs and wire it to a constant source.
