help with starting problem
so i think it might be the solonoid but i dont know, it is new just put it on yesterday cause my truck wouldnt start and i couldnt jump it.
so what would make it spark like that when i try to connect the batterty ?
could it be the ignition switch ?
and i couldnt pull the cable they were on tight, so i ran to go get a wrech from my garage and by the time i ran and got it it died !
thanks for your help
Sometimes solenoids are used when the battery power is too low and the contacts inside become welded together causing a constant crank condition when a fiully charged battery is installed.
You never mentioned if you replaced the solenoid before you hooked up the battery.
my truck dosnt want to start all the time. we were out at a strip pit party last nigth and i had to leave my truck there cuase it woudlnt start. i thought it just need a jump but it didnt help. it was cranking fine but wasnt starting at all.
so i left it over night and came back the next morning and it fired right up so i took it home and drove it to town tonight and let it sit in a parling lot for an hour or so and go to move it and it starts and drives then i stop and it dies and wont restart.
later on it start gets to another part of town and then i let it sit there and it starts when i go to take my friend home, then next time i try to go home it wont start !
i thought it was the fuel pump but i can hear it running when i get under the truck. is there one in the tank also ? could it be the ingition modual ?-spelling
the starter,solonoid, and altanator are new. plugs are fairly new, what coudld thois be ? fuel or spark is what it lacks but i have yet to pulla plug and check for spark .
so can anyone tell me if there is a pump in the gas tank.
