Input jack on Ranger CD player
Old Aug 14, 2006 | 07:39 PM
Seronac's Avatar
Seronac
I've been wondering about some way to install an input jack in my Ranger so that I can plug in an MP3 player.
Both of my vehicles (2000 Ranger XLT and 2000 Windstar) had the option of a CD changer. I was thinking that if I could figure out the correct layout of the CD changer input, then I could mount a input jack on the dash and run it to the appropriate connectors on the CD changer input. I can't see why it wouldn't work, but I need to find the connector schematics and my shop manual (on CD) doesn't go into that detail.
Any tips/ideas/suggestions?
Thanks in advance.
Old Aug 14, 2006 | 07:44 PM
Alan D.'s Avatar
Alan D.
Well, i wanted to do what you are trying to do. i got parts leftover. i oretty much when out and bought this. Sony CDX-GT300. it looks great, sounds great, and ha this cool jack that you can plug a cord ino. perfect for your mp3 play, in my case a palmpilot.
Old Aug 14, 2006 | 07:47 PM
Alan D.'s Avatar
Alan D.
it was 139.99 and came with everything needed. i actually like it betyter than the OEM system, better sound quality. but i have 4 amps installed, with an eight-speaker bose system.
Old Aug 14, 2006 | 08:11 PM
FTE Trigger's Avatar
FTE Trigger
USA Spec has one that uses the Aux. connection spot for the CD changer. I their set-up takes into account the variations in some of the volume levels that a add-on Mp3 player type item may otherwise have a problem with when being routed into a OE Radio ...
This was the only link I could find at the moment... http://www.crutchfield.com/S-41wKu0x...450&I=581DFF20
Edit: After looking around more, I suppose if you did get your hands on the Pin-out sheets- this could be very feasible. I just don't know what kind of quality of sound you'll get right off the MP3 player being washed into the back of the radio HU
Old Aug 14, 2006 | 08:23 PM
Seronac's Avatar
Seronac
That's about what I wanted to do; it's for my palmOne LifeDrive. But I'm not interested in spending lots of money on it. I spent about $20 on an FM transmitter that connects to the headphone jack on my handheld. It works OK, except for occasional interference, typical for radio. If I can't do this for less than $30-$40 then I probably won't bother. But it would be sweet.
Thanks for the responses, guys.
Any more comments/tips/suggestions would still be welcome.
Old Aug 14, 2006 | 08:25 PM
Seronac's Avatar
Seronac
Originally Posted by 99Trigger3_0
USA Spec has one that uses the Aux. connection spot for the CD changer. I their set-up takes into account the variations in Hi-Lo frequencies/volume levels that a add-on Mp3 player type item may otherwise have a problem with when being routed into a OE Radio ...
That one's a possibility, but I'd have to really want it to spend that kind of cash on it.
Old Aug 14, 2006 | 08:32 PM
FTE Trigger
I did a bit of editing above...
I'll see if I can find a Pin-out sheet for that Aux. jack..
Old Aug 15, 2006 | 09:26 AM
sfcwoodret's Avatar
sfcwoodret
JVC has good ratings for vehicle stereo systems with all the bells and whistles needed.
