Tranny fluid?
Old Aug 14, 2006 | 06:36 PM
ponch37300's Avatar
ponch37300
Tranny fluid?
I just recieved my valve body from bts today. I tho9ught it would be a good time to change the tranny fluid since it's probally not been done, at 63000 miles. All the local auto stores only carry thier own brand of cheap atf. I read in the article section i will need about 20 quarts. Where can i find some good stuff locally, i was thinking synthetic. Or do i have to order it online somewhere. What brand and type of atf should i get. Thanks for your help
Old Aug 14, 2006 | 09:21 PM
aklim's Avatar
aklim
I use Amsoil or you can use Mobil 1
Old Aug 14, 2006 | 09:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i use Amsoil Torque drive and love it. 20qt=5 gallons, and i bought two 2.5 gal jugs of the stuff from a friend over the net who was an amsoil dealer. it was around $180 i think, and it's good stuff.
when you change fluid, you need to flush it all out with new. it holds ~19 qts, and if you just drain the pan and refill, you are only really draining about 6.
go to this link to see how to do it:
https://www.ford-trucks.com/article/...nsmission.html
Old Aug 14, 2006 | 10:05 PM
aklim's Avatar
aklim
The way I did it was to drain TC and drop the pan. Then disconnect the lines and blow them
Old Aug 14, 2006 | 10:40 PM
hink10's Avatar
hink10
An '03 won't have a TC drain plug, you will have to flush. The procedure in the link posted by Strokin works well.
Old Aug 14, 2006 | 10:48 PM
ponch37300's Avatar
ponch37300
I read the article on here about changing the fluid and it said that after 2001 the tc doesn't have a drain plug on it. I have a 03 so how do i drain the tc. Thanks
Old Aug 14, 2006 | 11:19 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I just got the AMSOIL card, I am going to buy all the necessary fluid
Are you running it in everything in your truck>?
Old Aug 14, 2006 | 11:24 PM
ponch37300's Avatar
ponch37300
Right now as far as i know, only had the truck since feb., the fluid is stock. I would like to change my trans fluid now and the diffs soon after. Heard amsoil is expensive but good. What do you mean you just got your amsoil card toyota hauler.
Old Aug 14, 2006 | 11:32 PM
aklim's Avatar
aklim
Power Steering and Trans and Rear end and Front diff and the transfer case.
Old Aug 14, 2006 | 11:34 PM
aklim's Avatar
aklim
I thought all the 4R100s have a drain plug or is it up to the 01s? Doesn't matter. BTS set me up with a PI TC and it doesn't. Just cirious. How did you know he has an 03?
Old Aug 14, 2006 | 11:38 PM
hink10's Avatar
hink10
The article says if trans made after August '01. I checked out his signature and saw it was an '03.
BobbyDiesel71
where in cheesehead land are you? LOl
jk
I am located near Chicago
I became a "dealer" and can sell you fluid and you can have it sent to you or pick it up from a local WI dealer or me in IL
You can do the membership yourself and get a 20% discount
ponch37300's Avatar
ponch37300
aklam...It's in my signature on the top right corner of my post. It says in the article section of this forum(the link strokin gave) says trans built after augest of 01 don't have the plug. Wish i could afford your tc
Old Aug 14, 2006 | 11:42 PM
aklim's Avatar
aklim
OK, I didn't read the article carefully. I didn't see your sig. Must be because I am a free member. Should look into changing that.
I am just glad you didn't have my TC. If you did, that means you have had to have a rebuild. That cost me about $4300 for the trans and 250 for the install
Old Aug 14, 2006 | 11:52 PM
ponch37300's Avatar
ponch37300
Toyota Hauler...I am in appleton, close to green bay. How do you do the membership? I will be going to new york city at the end of the month but would like to get my tranny done by then. I am interested in the rest of the fluids though. Can anyone become a member, does it cost money? Thanks
