Oil leak!
Old Aug 14, 2006 | 06:00 PM
TIM PADGETT's Avatar
TIM PADGETT
Oil leak!
My 04 is in the shop; check engine light and oil leak. S/A says it's an oil pan leak and bthey need to "lift" the engine to pull the pan? Has anyone heard of this? My truck has a 6.5 inch lift, would seem there is plenty of room to drop the pan. Any ideas?
Thanks...
Old Aug 14, 2006 | 06:19 PM
vloney's Avatar
vloney
theres a cross member under there that prevents removal unless you lift it up. You could have a foot lift and it wouldnt matter.
Old Aug 14, 2006 | 06:33 PM
CanadaGuy's Avatar
CanadaGuy
To this day, I have yet to see an oil pan leak on a 6.0. Unless ofcourse they've been mashed somehow.
Old Aug 14, 2006 | 06:51 PM
BowTieHatr's Avatar
BowTieHatr
probably glow plug harness.... just did one toda yippie!!
Old Aug 14, 2006 | 06:54 PM
CanadaGuy's Avatar
CanadaGuy
I'd take a glow plug harness over a bed-plate leak anyday!
BowTieHatr's Avatar
BowTieHatr
i hear ya!!
Old Aug 14, 2006 | 06:55 PM
TIM PADGETT
I searched old posts and could not find any oil pan leaks either. Originally they thought it was the rear seal, previously they repaired/replaced the CPS seal/o-ring.
Thanks, I wasn't sure about the motor cross-member, couldn't remember where it was in relation to the oil pan.
I really like this dealership and there service department. Power Ford of Torrance. Very helpful.
Old Aug 14, 2006 | 06:58 PM
CanadaGuy's Avatar
CanadaGuy
Sounds like a bed-plate...
Old Aug 14, 2006 | 07:30 PM
laredo7mma's Avatar
laredo7mma
Hey CanadaGuy or BowTieHatr, my local Ford Tech has tried to repair my glow plug harness three times and it is still leaking. The last time he put some silicon type sealer on it to try to stop it, is that a normal fix? What causes a perpetual leak like this? Poor machining? Wrong tolerances?
Thanks for your help and sorry if I am high jacking this thread.
Old Aug 14, 2006 | 07:43 PM
TIM PADGETT
Bed plate? Where the oil pan seals against the block? Also, we ran dye in the oil for about forty miles, that's what made the tech think it was/is the oil pan/bed plate seal, instead of the rear seal.
Old Aug 14, 2006 | 08:59 PM
jekuo's Avatar
jekuo
I had the same leak and they removed the engine and resealed everything. All is good now, and no more leaks. Sounds drastic, but it's sometimes the only way to go.
Old Aug 15, 2006 | 02:33 AM
jonsk's Avatar
jonsk
my brothers 6.0 oilpan rotted out at around 100,000 miles. He plows for the city and thought that all the salt and road deprise aided this failure. Hes a diesel mechanic and said the motor needed to be lifted to replace it. Oh yeah, just beyond warrenty.
Old Aug 15, 2006 | 12:51 PM
superduty_rhino's Avatar
superduty_rhino
Thanks, all!
Tim
Old Aug 15, 2006 | 06:38 PM
CanadaGuy's Avatar
CanadaGuy
I replace leaking glow plug harnesses. I've never had one leak twice.
Old Aug 15, 2006 | 06:58 PM
laredo7mma's Avatar
laredo7mma
Hmmm, that must be the problem, they keep replacing the O-rings only, not the harness.
Thanks!
