did a search still need help
Old Aug 14, 2006 | 05:13 PM
61fordf250's Avatar
61fordf250
Wink did a search still need help
Alright i did a search for how to take a steering column out of a 61 F250. Is it true it is one piece or could i pry it up and out?? I appreciate everything everyone has suggested. I have decided to restore her. Not many around anymore and it has been a dream to restore one. It will involve patience.
Old Aug 14, 2006 | 05:50 PM
hiball3985's Avatar
hiball3985
to remove the column, remove steering wheel, 2 bolts to dash, and any linkage for gear shift, disconnect wiring harness from column, and it should slide out
Old Aug 14, 2006 | 09:19 PM
carras's Avatar
carras
Not sure 'bout the 61, but my 66 has a plate on the firewall (in the engine compartment) where the column is clamped on. I had to remove this as well to get my column off
Old Aug 14, 2006 | 11:29 PM
airharley's Avatar
airharley
If remember right 61's had a solid shaft that went all the way into the steering box. The only way to get it out is to unbolt the box from the frame, pull off the idle arm, disconnect the wiring, remove the floor opening panel, unbolt the 2 bolts holding the column to the dash, and remove as one piece.
Old Aug 15, 2006 | 09:23 AM
cobraguy's Avatar
cobraguy
All the straight axle trucks I've worked on had a one piece colum and steering gear. to remove it you have to remove the drag link, three bolts on the frame, the tin plate on the floor, two bolts to the dash, turnsignal harness, removing the steering wheel gives you more room but is not always necessary. Also the horn wire runs through and out the bottom of the steering gear box.
JeanPallitta
Large Truck
Dec 22, 2013 04:08 PM
Ford-ified
Feb 8, 2012 09:52 AM
mnjbailey
Large Truck
Mar 5, 2010 05:08 PM
sparky69
Offroad & 4x4
Dec 26, 2005 07:23 PM
Double T
Dec 2, 2003 03:40 PM
