Offroad & 4x4
Big @$$ build up
Old Aug 16, 2006 | 06:55 PM
bremen242's Avatar
bremen242
Originally Posted by blucollar4xford
possible. also, im not 100% worried about the MAX rpm out of a 514, i myself know a few people in the local pulling circuit who ran a 514 back in the 80's doing nearly 8,000 rpm. but wouldnt a 429 reach high R's quicker than a 514 due to the shorter stroke? or is that even right? i'd love to run a 514, but 514's are hard to find outside a parts catalogue. this
514s are merely a 460 (or 429 IIRC) block with a longer stroke crank and BB Chevy rods.
you can order a 514 crank from summit for a decent price.
Old Aug 16, 2006 | 10:00 PM
ivanribic's Avatar
ivanribic
There are a lot of factors in how quickly you can reach max RPM with an engine. Stroke will effect it but I guarantee you if you have a properly built 514 (I'd recommend much bigger than 514 for your purposes honestly) with heads that flow and a cam set up properly you'll hit 7,000rpm so fast you'll crap yourself.
Old Aug 16, 2006 | 11:56 PM
fordraceboy's Avatar
fordraceboy
well put..
you mean kinda like when you build a 700 horse motor then hit the 200 shot of giggle gas?
Old Aug 17, 2006 | 12:10 AM
ivanribic's Avatar
ivanribic
Well, my last engine with a very mild cam and Trick Flow heads would bounce off a 6000 rev limiter in no time. If I just made a split second tap to the floor and let off it would flash the shift light. Take a really good head with a nasty cam and see what happens. Ask Rob how fast his stroker hits the limiter and I think his is close to 8000.
Old Aug 17, 2006 | 01:37 PM
Skipped_link's Avatar
Skipped_link
To bad you live so far away, I've got a set of tires & wheels for your build, but shipping would probably kill you,
Old Aug 17, 2006 | 02:50 PM
ivanribic's Avatar
ivanribic
What kind of tires and wheels do you have Leroy?
Old Aug 17, 2006 | 03:21 PM
Skipped_link
They are Firestones, aprox. 55" tall & 25" wide, on open center wheels, they are a turf tread, but would be good for doing a build up, then when finished they could be run till a more agressive tread could be afforded,
That was always my plan for them anyway, I really liked the open center wheels, a guy could easily build a sent of centers for what ever diff's he decides to use,
I'll see if I can get some pics & post them,
Old Aug 17, 2006 | 03:24 PM
Skipped_link
Old Aug 17, 2006 | 03:25 PM
chrono4's Avatar
chrono4
holy crap is that your backyard?
Old Aug 17, 2006 | 03:29 PM
Skipped_link
Some of it,
The pile of chevys in the back ground is the neihbors place.
You can't really see all my junk,
Old Aug 17, 2006 | 06:22 PM
blucollar4xford's Avatar
blucollar4xford
so what is "decent" for a 514 crank? how bout some rods? and i have no idea what size cam i will need, im totally lost in the cam dept.
but there is a 1-ton 4x4 down the road that has a 460 in it i am thinking of buying (for many reasons) but if i can get it to be as responsive as you all say they can be you have just converted me.
Old Aug 17, 2006 | 06:26 PM
monsterbaby's Avatar
monsterbaby
Close to 8000rpm? no it's right at 8000rpm, and it will hit that when free reving before you can get your foot clear to the floor and infact I am not sure I can even get the secondaries open before the shift light is on. And I can hit the 7400rpm shift light 3 times (yes that means in third gear the shift light is on) and push the 8000 rpm limiter in third in under 4 seconds.
Old Aug 18, 2006 | 12:08 AM
  #28
blucollar4xford
damn...that sounds like a wild *** engine. what are you turning over?
Old Aug 18, 2006 | 12:14 AM
  #29
fordraceboy
The whole truck..
sorry man, couldn't resist!
Old Aug 18, 2006 | 12:20 AM
  #30
monsterbaby
Originally Posted by fordraceboy
The whole truck..
Yeah, yeah, oh well I guess I deserve that with my sig.
Blue collar not sure what you are asking other than the whole truck.
