Help!!
Old Aug 13, 2006 | 12:48 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Cool Help!!
I just started my routine oil change and when I took off the oil filter a flat round and a normal washer along with a spring about two inches long fell out. How bad is this and how do I fix this? I need to get it going for work tomarrow. Thanks in advance for the help fellas!!
Old Aug 13, 2006 | 04:00 PM
ltfox's Avatar
ltfox
Sounds like the oil filter relief. On my 94 it was held in by pinging the metal around the hole just enough to hold it in.
Old Aug 13, 2006 | 04:14 PM
1997F-350's Avatar
1997F-350
did you see the little screen anywhere?
Old Aug 13, 2006 | 04:49 PM
1997F-350's Avatar
1997F-350
here you go courtesy of kwiks photos
although his is a 99.5 i think they are the same. last time i looked up in there anyway.
i know for a fact we have the screen i have seen mine before. and if you found the washer i can only assume you need the c clip also. making obs to nbs identical.
Old Aug 13, 2006 | 04:52 PM
Stroker 94 1/2
There was a flat carbon like washer a spring and a normal washer. It looks like the flat carbon like washer goes in first, then the spring, then the washer with a hole in it holds it all in. Does this sound right? Do you just tap the washer with the hole in it into place and thats it? I figured I'd try that if you guys say its alright. Thanks for the help!!
Old Aug 13, 2006 | 04:54 PM
1997F-350's Avatar
1997F-350
refer to the pic above. i believe this is what all you need to have and install in order the pic shows.
Old Aug 13, 2006 | 04:55 PM
Stroker 94 1/2
I was writing my last reply when you posted the pic. Yes thats all that was there except the c-clip.
Old Aug 13, 2006 | 04:57 PM
Stroker 94 1/2
So the spring goes in first?
1997F-350's Avatar
1997F-350
you can buy those at most hardware stores and they are open sundays. just buy a couple close sizes in comparison to the washer and try em out. good luck
Old Aug 13, 2006 | 05:21 PM
Stroker 94 1/2
Sorry for the repost but we were writing at the same time. Does the spring go in first?
Old Aug 14, 2006 | 01:14 AM
1997F-350's Avatar
1997F-350
yeah if i am not mistakin it should all go in the hole in that order. it only makes sense to me thats how it goes.
Old Aug 14, 2006 | 11:06 AM
Stroker 94 1/2
I got it back in but there was no ring in there for the c-clip to fit in. I used a socket the same size as the washer and pressed it back in. Well I guess I'll see if it holds it in at the next oil change. Thanks for the help!!
