dont know which engine
Old Aug 13, 2006 | 03:42 AM
jtsulujian's Avatar
jtsulujian
i've inherited a 1975 F 600. it ran great last time i drove it 2 yrs ago. but now not so great. i want to give it a tune up but i dont know what engine it's got. i found some #'s on the block. the # on the drivers side is small and reads 6c22 or gc22, there are larger #'s on the passenger side of the block they read u4te or D4te. any help would be greatly appreciated in identifying this engine. oh yeah, its a gas engine.
thanks
jts
Old Aug 13, 2006 | 08:07 AM
BigShelby's Avatar
BigShelby
Get the VIN, goto Mil1on's website and find the VIN decoder. This will tell you what engine was installed from the factory. Not sure though if the VIN decode works for F600 but it's worth a try.
Old Aug 13, 2006 | 04:12 PM
Mil1ion's Avatar
Mil1ion
6c22
That is a date casting
March 22nd/1976
D4TE is the design date and application for the part
1974 Truck Engine part
The casting date carries it over to March 1976 and your truck was probably built within 5 weeks of that (last 6 digits of Vin#)
I suggest you have one of these.
330,361,391 ?
What is the 4th digit of the VIN#
Old Aug 13, 2006 | 05:32 PM
jtsulujian's Avatar
jtsulujian
Thank you both. the VIN is F61EVV43148.
Old Aug 13, 2006 | 09:27 PM
Mil1ion's Avatar
Mil1ion
Engine code E is a 361 4v HD engine.
Old Aug 20, 2006 | 06:23 PM
jtsulujian's Avatar
jtsulujian
Again, thanks. f600 is running great now and i am using it. it's a blast to drive. no real mufflers, just glaspacks. you hear it coming a mile away. steerings a little loose, but i can deal with that. thanks much. the other trucks i've got to work on now are a 67 gmc dumper with a huge V6 and a 66 or 7 chev spartan with seemingly the same 401M engine. I'll have to find a gm forum for those, but thanks again. JTS
Old Oct 2, 2006 | 10:00 AM
haroldservice's Avatar
haroldservice
Ford F700 vin
ANy info on vin Number for 73-75 F700(or FB700)? #N71BVFE8502. other numbers 24,000gvw, N7124A8, JL, 54M, 712369. In Particular am looking to find out which engine. thnaks, harold.
Old Oct 2, 2006 | 07:24 PM
Mil1ion's Avatar
Mil1ion
F series ended with 600 back in mid the 70's.
The 700 was an L or N series truck (heavy duty)
Because most of my literture only cover F series it gets difficult to decode L-N- series trucks
for your vin#
N71BVFE8502
N71- Short conventional N-700 series
B - ? how many cylinders ? could be 300 or 360
There isn't a B code for a 76 N-700 truck
V - Kentucky Truck Plant
FE8502 Build number - This group of digits represents a 79 built number.
Old Oct 2, 2006 | 07:35 PM
haroldservice
thanks for looking this up!
