Some Engine Help plz
Old Aug 12, 2006 | 12:00 PM
RussianWolf's Avatar
RussianWolf
Arrow Some Engine Help plz
Well I bought a truck for 350$.
Its an old 1984 Flatbed F160. 2 Wheel Drive.
But besides the point.
I have been told that it has 3 different engines.
A 351 Windsor.
351 Cleveland
351 Modified.
About 90% of people say its a windsor but I dont think it is.
I know i came out of a 76 Torino.
Ill post a pic I took of it... Can someone tell me what it really is?
Thanks,
Aaron
Old Aug 12, 2006 | 01:16 PM
Sycostang67's Avatar
Sycostang67
Looking at the valve covers I would guess it's a 351W. Does the water neck bolt to the intake manifold or the block?
Old Aug 12, 2006 | 02:31 PM
littleme13's Avatar
littleme13
there is a way you can tell by counting the number of bolts in the valve cover but i cant remeber what it is. one way i do know is pull off the rocker cover and if the valves are side by side is a windsor if they are stagered is a modified or cleavland. im going to guess and say a windsor cause the covers look too narrow
Old Aug 12, 2006 | 03:16 PM
RussianWolf
The water neck bolts to the block. And the radiator hose connects at a 90* angle. I heard that makes a difference
Old Aug 13, 2006 | 08:42 AM
Sycostang67
Well then it's definitely not a 351W. I am changing my vote to the 351C. I haven't heard of a 351M in a torino either(not saying it never happened, I just haven't seen it) so that would also lead me to believe it's a 351C. One more thing to check. My 351C has 8 bolts per valve cover, how many do you have?
Old Aug 13, 2006 | 10:46 AM
RussianWolf
It has 7. 1 is missing. :P
Old Aug 13, 2006 | 06:26 PM
littleme13's Avatar
littleme13
the modified also has 8 bolts if im not mistaken but i would say a cleavland also due to me newver hearing of a modified in a torino. i would try and find a casting number on the block to find out for sure thou
Old Aug 13, 2006 | 06:42 PM
8 Lugs's Avatar
8 Lugs
351W! No question about it!
Steve G.
