temp sending unit
Old Aug 11, 2006 | 10:29 PM
chrono4's Avatar
chrono4
temp sending unit
where does the sending unit usually go on a c6 for temp gauge? would a regular engine gauge work, it starts at 100, stops at 260. thanks guys.
Old Aug 12, 2006 | 08:49 AM
stuart1's Avatar
stuart1
In the cooling line going to the cooler.
Transmissions can run hotter than 260.
Not for long but they can.
Old Aug 12, 2006 | 09:07 AM
chrono4's Avatar
chrono4
would it be ok to tie in there with a t, and read from that? I dont plan on going over 260, and if it hit that i would just have to back off.
Old Aug 12, 2006 | 09:09 AM
stuart1's Avatar
stuart1
Yes, a "T" fitting will work fine.
The other option is to poke a hole in the pan.
The cooler line gives you a real time temperature though.
