Sponsored by: Auxito
T-bars
Old Aug 11, 2006 | 10:06 AM
fordman311's Avatar
fordman311
T-bars
So I want to replace my right front t-bar before I lift the truck. So probably better off just getting two new ones. The right one sags pretty good. Anyone know iif I get get t-bars from anyone other than ford? I doubt there is much of a market for aftermarket torsion bars but just thought I'd check.
Old Aug 11, 2006 | 09:39 PM
Ultramagdan's Avatar
Ultramagdan
Are you sure it's bad? Or just not tight.
Old Aug 11, 2006 | 10:27 PM
fordman311's Avatar
fordman311
It's sitting about an inch lower on the right side. To the point that my 265/75 tire rubbed enough for me to have to trim. Most people fit 285's without rubbing. The bolts are tightened equally (same amount of thread showing).
Old Sep 15, 2006 | 03:54 PM
tim.moman's Avatar
tim.moman
My 98 F150 is doing similar. The left side sags (more with a load). This machine has done extensive desert offroading. I replaced the rear leafs and gained about 2 inches of ride height back. (Factory leafs). Front is maxed on adjustment as still notably low. So I am looking to replace the bars as well. I heard a rumor that the chevy bars hold up better. But I cannot find information about swaps.
Ford quoted about $60 each. But could not tell me that it was the correct part. Flaky parts guy.
Old Sep 20, 2006 | 10:31 PM
fordman311's Avatar
fordman311
i've heard of chevy guys swapping the keys from thier trucks for ford keys because ford has more lift in theirs. I'll pm you a link that might help you.
