OPtions on vehicle.
It has as options so far that I have noticed: (just got her yesterday)
power sunroof
6 disc changer and subwoofer
2nd row captains
side airbags
back up sensor...
is there a link somewhere that I can't find?
thanks again.
Option Packages:
Heavy Duty Trailer Tow Package (req. 3.73 axle) (includes 4-pin & 7-pin wire harness, heavy duty transmission oil cooler, heavy duty radiator, Class IV hitch/receiver, and electronic braking wiring kit) - you'll know you have this if you have the 7-pin wire harness right next to the hitch receiver
Safety and Security Package (includes Safety Canopy™ and Reverse Sensing System) w/Message Center - you have this (it's required for the moonroof and starting in 05 it was the only way to get the reverse sensing option)
Individual Options:
HomeLink® - programmable garage door opener, I think this is built into the driver's visor
Navigation Radio - you don't have this
Power Quarter Flip Windows - switches are in overhead console in front of moonroof
2nd Row Captain's Chairs - you have this
3rd Row PowerFold™ - sounds like you have this
Climate Controlled, heated and cooled driver and passenger seats
Rear Seat Entertainment DVD w/Wireless Headphones
AdvanceTrac® w/Roll Stability Control™, Non-Limited Slip Axle - if you have this you will see a shutoff switch in the center console, between the cupholders
Air Suspension Four-Corner Load Leveling w/Message Center
Axle, Limited Slip Rear (3.73 Ratio) (NA w/AdvanceTrac® w/Roll Stability Control™)
Axle, Non-Limited Slip Rear (3.73 Ratio) - optional with 4x2, standard with 4x4
Black Roof Rails w/Black Crossbars
Moonroof, Power (req. Safety and Security Package)
