Automatic trans coolers
Old Aug 9, 2006 | 11:22 AM
mldmkr1960's Avatar
mldmkr1960
I was wondering about the flow in my transmission coolor. Its vertical and wanted to know does it go in the upper end and flow down like the coolant or does it enter the bottom and go out thru the top. I want to check the flow and flush some out thru a fitting and hose.
Old Aug 9, 2006 | 11:47 AM
stuart1's Avatar
stuart1
The hot fluid should enter the top fitting and exit from the bottom.
