Sponsored by: Kumho
play in steering
Old Aug 9, 2006 | 10:05 AM
79roush's Avatar
79roush
play in steering
I have a 79 f100 6cyl and it has a play in the steering. I have had the front end parts checked out and everything is ok. Should I try to tighten the gear box or does anyone have other suggestions. Also can you buy a rebuild kit for the gear box.
Old Aug 9, 2006 | 10:25 AM
1975Ford's Avatar
1975Ford
If the front steering and suspension parts have been examined for wear.
Check the steering coupler (aka rag joint) on steering shaft for wear.
Here a link on adjusting the steering gear box. https://www.ford-trucks.com/forums/2...-loose%3F.html
Try adjusting in 1/8 turn increments the sector shaft adjustment screw by loosing the nut on the base of sector shaft cap. https://www.ford-trucks.com/user_gal...=94743&width=0 Make sure not to overtighten this screw because it can damage the steering gear box. Take your time.
buck
