Upfitter Switch Wiring Question 2006
I've been through the manual, and found the relays up behind the glove box. What I can't find are the "4 blunt cut orange wires behind the passenger compartment fuse panel" (as the manual says).
What I do see is under the hood on the driver's side, 4 cut wires right above the fuse block, but they are red, white, blue and black. Are these the power leads for the switches and, if so, do you know which goes to which?
I've been up, under and around the fuse panel under the steering wheel and if they are there, i sure can't see them (this is where the manual said they are). Of course, it would make a lot more sense for them to be under the hood, or you'd have to find your way throught he firewall to hook up lights, etc.
Help? Thanks!
Help? Thanks!
The blunt cut wires under the hood are not them. Not sure what they are for, but that is not the wires you need.
The blunt cut wires you need are terinated with a black coating and are behind the driver side fuse panel. If you pull the 4 bolts off and pull the fuse panel down, you should find them pretty easily. I originally thought they were behind the passenger fuse panel, and when I couldn't find the blunt cut leads, I just cut the wires and butt-connected directly there.
Basically you have two options:
1) Pull the driver fuse panel down and find the blunt cut wires, or
2) Cut the wires behind the passenger fuse panel and hook up there.
hope this helps...
Rich
hope this helps...
Rich
Originally Posted by Green_Dually
LOL no there not.There customer access wires.They are wires that go though the firewall,to make wiring of light etc,etc,etc easier.
my guess is they are wires that are pre-run through the firewall but are not connected to anything on either side? is this correct?
I have an 06 SD SC 4x4 V-10 Lariat........ I also help build the Super-Duty truck at the KY truck plant. The above wires I mentioned DO go to the plow package. The up fitter wires are as explained before are under the Fuse panel. I am not the engineer who put them there.....but you have to drop the drivers side fuse panel and the 4 Orange wires will be marked 1,2,3, and 4 for the four switches. Thanks
