Modular V10 (6.8l)
V10 Brothers please help
Old Aug 21, 2006 | 04:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Any Ford piston slap is a non-destructive problem. Unlike Chevy's problems with it.
There are inserts for the spark plug holes, that can be installed without pulling the head off the motor.
If you can get it cheap, DO IT! Get it home, do the plugs the RIGHT way (read the FAQ at the top of this forum) and be comfortable. If while you're in there, one of the plugs comes out with the aluminum threads stuck to it, fix it right away.
I don't think you can go wrong, if you need an SD's size and capabilities.
Old Aug 23, 2006 | 10:51 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
The V10 with the auto trans is one sweet set-up. You will not regret it!
Old Aug 24, 2006 | 10:15 AM
ToaDisco's Avatar
ToaDisco
Originally Posted by zomble1243
thanks for the imput, so what I am getting from this is the 99 isnt a good idea cause of early issues with the motor....btw what were the fixes for the spark plug issue, was it just loosening up or pulling the threads out?? and also on the piston slap if anyone knows....Much appreciated guys Alan
If the truck looks like it is in good shape, and if the right price, I wouldn't count it out just because its a 99'. I have a 99' F250 with close to 120,000 miles on it and it runs like a top. I did have a plug blow out on me, and after it was all said and done, it wasn't all that expensive or hard to fix. Just keep the plugs torqued to 14 ft/lbs and all should be fine. I have never experienced any piston slap either in the 20,000 miles I have owned it. Overall its an excellent motor and truck
Old Sep 5, 2006 | 07:28 PM
my99f250's Avatar
my99f250
i have a 1999 ford f250 superduty with the 6.8l v10.it has 180,000 on it now. love the truck!!! never had a spark plug come out. never had a problem with piston slap. only problem ive had was spark plug boots rotting out, and a cracked flywheel. still running strong!!! love it!!!
Razorbackfan
Jan 2, 2012 10:08 PM
TJDave
New Member Introductions
Jan 22, 2011 08:46 PM
jndinmo
Modular V10 (6.8l)
Nov 30, 2010 09:34 AM
super 6.8
Sep 4, 2006 09:49 PM
JML79
Modular V10 (6.8l)
13
Oct 25, 2004 08:37 AM
