blower switch replacement
Old Aug 8, 2006 | 06:20 PM
puck1263's Avatar
puck1263
How easy is it to replace the A/C blower switch? Ford only has the unit as a whole to replace, but parts stores have the individual switch. Can only the switch be replaced?
Old Aug 9, 2006 | 05:38 AM
mississauga's Avatar
mississauga
I have never replaced it, but looking at my spare from an 88 there are 2 screws holding it on the the assembly. The blower motor switch is also attatched to the same assembly. To get at it , the trim piece has 4 clips holding it on which is a matter of carefully pulling off. Underneath there is 4 screws holding the assembly in place. Once removed you can disconnect the electrical harness ,vaccum hose connector and slide wire and the whole thing can come out. I think the hard part is getting to the switch but that isnt really that tough.
Old Aug 9, 2006 | 02:59 PM
lostin90s's Avatar
lostin90s
What year is it and why need replaced? Just wondered my fan would only work on high went to get replacement . Parts man said it was a sensor beside blower in engine compartment. Easy fix . But I think the one I took out of my 93 is all one peice but didn't look that close. If I can find it I'll see. Good luck.
__________________________________
94 Ford XLT 4x4 super cab long bed MAF 302 at
Old Aug 9, 2006 | 08:38 PM
puck1263's Avatar
puck1263
Got-r-done and back to proper operation. Parts store had one in stock. 4 easy clips, 4 easy screws, one screw on the switch, properly pulled **** off, unplugged from harness. Install reverse.
Looks like it got pretty hot. The switch was black and the harness was melted.
Old Aug 9, 2006 | 08:45 PM
mississauga
Glad you got it fixed. Sounds like it is the blower motor switch that was the problem.
mribbich
May 19, 2016 01:22 PM
dessmo
Feb 14, 2016 11:01 AM
zerocoolsob
13
Nov 30, 2014 10:08 AM
MikeBlansfield
Oct 16, 2014 06:02 AM
fixit5561
Jul 27, 2010 01:59 PM
