05 e-350 6.0 problem
Old Aug 8, 2006 | 04:00 PM
Brian1477's Avatar
Brian1477
05 e-350 6.0 problemidles fine when you take off from a standstill it lacks power and smokes black and then power suddenly comes in and smoke goes away and then is fine untill you take off again from either a stop or crawl. no check engine light. Is this a turbo problem possibly? any input I would appreciate Thanks
Old Aug 8, 2006 | 07:09 PM
CanadaGuy's Avatar
CanadaGuy
Sounds like an EGR valve to me.
Old Aug 9, 2006 | 04:10 PM
Brian1477's Avatar
Brian1477
wouldn't that set a code or maybe doesn't do it long enough to set code
Old Aug 9, 2006 | 08:00 PM
CanadaGuy's Avatar
CanadaGuy
It would likely have set a code, but not necessarily turn the CEL on.
Old Aug 9, 2006 | 08:32 PM
BowTieHatr's Avatar
BowTieHatr
egr valve exspeacially if it idles alot
Old Aug 10, 2006 | 03:45 PM
Brian1477's Avatar
Brian1477
it does idle alot thanks for the input
Old Aug 10, 2006 | 08:36 PM
BowTieHatr's Avatar
BowTieHatr
thats what we are here for, let us know what happens ok!!
