Is there a Difference?
Old Aug 8, 2006 | 02:54 PM
d_stange's Avatar
d_stange
What is the difference between the "Check Engine" light and the "Engine" light. Does the "engine" light mean anything? My 1988 F150 5.0l has been running and dyeing the last few days and the "engine" light will come on. What does this mean?
Old Aug 8, 2006 | 05:53 PM
EPNCSU2006's Avatar
EPNCSU2006
The "Engine" light comes on when there is no oil pressure, and on later trucks, when the engine overheats. It's just a light to make you check the gauges, nothing more. The "Check Engine" light is the one the computer turns on when it finds a problem.
Old Aug 9, 2006 | 07:33 AM
d_stange's Avatar
d_stange
NO OIL PRESSURE? well that's not good. must have bad oil pressure at low idle then right?
Old Aug 9, 2006 | 08:47 AM
EPNCSU2006's Avatar
EPNCSU2006
If the light comes on only when the engine stalls, there shouldn't be any problem.
Old Aug 9, 2006 | 08:50 AM
MustangGT221's Avatar
MustangGT221
Yeah if the light comes on after it stalls than that is normal.
You wouldn't have a clue if your engine has low engine oil at idle yet...ya gotta put a real gauge on it to know that. Factory gauge is worthless...it doesn't do much.
Old Aug 9, 2006 | 08:51 AM
d_stange's Avatar
d_stange
what if it comes on while its idleing or doesn't go off till after you rev it a little bit?
Old Aug 9, 2006 | 08:57 AM
MustangGT221
Then get an oil pressure gauge and check it...
Old Aug 9, 2006 | 09:00 AM
d_stange's Avatar
d_stange
GULP!!! Where do you screw an oil pressure gauge in? Into the sending unit. How many pounds of oil pressure should a 1988 5.0L be running? I'll check with my buddy i think they got one laying around the shop he works at to check things like that.
Old Aug 9, 2006 | 12:26 PM
andym's Avatar
andym
It only takes a few PSI to properly lubricate the engine, but a healthy motor will run between 40 and 60 cold.
Old Aug 9, 2006 | 01:52 PM
d_stange's Avatar
d_stange
I'll try and check it out tonight. Have a lot of projects going on but i want to see what's going on with this truck. I want to sell to pay some of the loan on my diesel. I'll keep you posted on what happens
Old Aug 9, 2006 | 06:23 PM
EPNCSU2006's Avatar
EPNCSU2006
Hot idle on my 87 is around 25-30 psi
Old Aug 9, 2006 | 06:26 PM
andym's Avatar
andym
Even if it's as low as 10 psi hot, you're ok, but start saving up money for a rebuild.
Old Aug 10, 2006 | 10:04 AM
d_stange's Avatar
d_stange
i plan on selling this truck so hopefully it hangs together for a while. I put a new coil in yesterday and it seems to not want to die now so i think i fixed that problem. the engine light came on once for about 10 sec and then went off when it was idleing warm so I think it's back on its feet again. Hopefully now i can sell it. Thanks for all the info.
Old Aug 10, 2006 | 10:18 AM
MustangGT221
20+psi at hot idle is ideal....less than that and there's an underlying issue.
Cold idle should be 40-60psi...
Then 10 psi per 1000 rpm is the general guideline.
Even 10psi at hot idle is adequate to lubricate but generally if it's that low at idle...something is wrong.
You need to unscrew the stock sending unit and install the sending unit for the gauge you're using, or if it's mechanical just the fittings.
Old Aug 10, 2006 | 10:49 AM
d_stange's Avatar
d_stange
What thread size is so i know what kind of fitting i can screw in it. I'm not going to install a gauge just want to check it with a gauge. Where is the sending unit located. Is it on the back of the motor? If the oil pressure is low could it just be the oil pump going bad or maybe the screen being plugged a little bit? Should i also check the compression?
