Sponsored by: Real Truck
Removing tail light assembly on '06?
Old Aug 8, 2006 | 12:37 PM
DeepDoc1's Avatar
DeepDoc1
Search seems to be broken for me right now. I need to remove the tail light assemnbly on my '02 F-250 to install a tool box. I removed the two obvious screws, but it seems there is something else holding it that I can't see. I have a stake pocket tie down, but do I need to remove it to get to another screw? Is there a reference for this kind of stuff, like removing door panels, removing headliner, pillar covers, etc? I checked the tech folder and saw the door panel listed, but that's it.
btw, has anyone ever installed a SwingBox tool box? I have the box and I like the idea, but I'm very unimpressed with installation instructions, and the company hasn't called me back yet.
Thanks in advance!
Old Aug 8, 2006 | 01:13 PM
ag-ford-4x4's Avatar
ag-ford-4x4
That light should pull out, it will PULL out, it will not just fall out once you get the screws out. They have some kind of ribbing somewhere that holds that light in, it should pull out straigt towards the back of the truck if i recall.
Old Aug 8, 2006 | 02:33 PM
DeepDoc1's Avatar
DeepDoc1
Thanks! You have confirmed info I got from another source, that there are only the 2 screws, and that the light pulls straight out with a bit of effort. I will try it again this weekend. Thanks again.
Old Aug 8, 2006 | 04:08 PM
ag-ford-4x4
Still, take it easy, dont use any tools, just your finger nails and some finesse. It will sound horrible when it comes out too.
Old Aug 8, 2006 | 05:16 PM
DeepDoc1's Avatar
DeepDoc1
Roger that. I found myself reaching for a 4x4 piece of cedar, but caught myself just in time....
Old Aug 8, 2006 | 05:45 PM
Bear Hunter's Avatar
Bear Hunter
Work your fingers around the outside edge of the tails (top and bottom) and pull straight out.
Old Aug 8, 2006 | 07:00 PM
ryaneverk2's Avatar
ryaneverk2
Yeah, it may seem like you'll break it, but just pull outward and it'll pop out. You'll see the tab things on the back of the housing that fit in the slots and see how it works once you've got it out.
